Author Topic: quick engine removal question  (Read 4900 times)
December 18, 2006, 01:44:30 pm
nkb
  • 154
« on: December 18, 2006, 01:44:30 pm »
i did a search but found everything but how to actually do it. 93 passat engine go down thru or up top? how long should it take and do i need any special tools besides the 8mm for the axles? im pulling motor and trans. i toasted the motor in my dd!!
2004 Jetta TDI
1997 GMC Suburban 6.5td
2002 S-10 AWD V8 turbo, Sy-clone
1986 S-10 LT1
Reply #1December 18, 2006, 02:07:28 pm
vwmike
  • Authorized Vendor
  • 1158
« Reply #1 on: December 18, 2006, 02:07:28 pm »
you should probably pull the engine out of the top. IF you were to try to lower it out the bottom you'd have to remove the subframe which would likely be more trouble than it's worth. You shouldn't need any other special tools.
Reply #2December 18, 2006, 02:10:35 pm
nkb
  • 154
« Reply #2 on: December 18, 2006, 02:10:35 pm »
awesome! thanks for the quick reply!! any idea on how long it should take? i don't think it would be long??
2004 Jetta TDI
1986 S-10 LT1
Reply #3December 18, 2006, 02:32:04 pm
vwmike
  • Authorized Vendor
  • 1158
« Reply #3 on: December 18, 2006, 02:32:04 pm »
It depends how fast you work and whether or not you have A/C and power steering. I'd guess an hour and a half if you're working quickly but not doing a junk yard pull (cutting everything).
Reply #4December 18, 2006, 09:31:24 pm
nkb
  • 154
« Reply #4 on: December 18, 2006, 09:31:24 pm »
so anyone know if i can just remove the engine??? i think i would rather just do that??
2004 Jetta TDI
1986 S-10 LT1
Reply #5December 19, 2006, 02:16:35 am
nkb
  • 154
« Reply #5 on: December 19, 2006, 02:16:35 am »
anyone? i can't tell if its gonna go, the balancer and w/p are hitting the body... if i take those off will it come alone? or does the trans have to come out too?
2004 Jetta TDI
1986 S-10 LT1
Reply #6December 19, 2006, 04:05:58 am
« Reply #6 on: December 19, 2006, 04:05:58 am »
You don't have to take the tranny out too, you could separate them and then support the tranny and leave it in there. I've never done it that way though.
If you take all of the accesories off the block, including the oil filter mount you should be able to drop it out the bottom. I've only done mk1 and mk2 rabbit/jettas so I don't know the specific configuration of the passat bay
