Author Topic: A2 Rotors to 81 Caddy  (Read 3786 times)
December 13, 2006, 10:22:11 am
somolovitch3
  • 290
« on: December 13, 2006, 10:22:11 am »
:? Can not seem to find answer, I know that I can bolt on A2 rotors and use thinner pads.
Are the A1 and A2 front calipers the same? Or should I get the A2 calipers and use stock pads?
tia
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #1December 22, 2006, 08:35:37 pm
moosiah
  • 106
« Reply #1 on: December 22, 2006, 08:35:37 pm »
sorry , the calipers a1- a2 are not the same........ and the pads for the vented rotors-in-a1-calipers are a stock part I run 10.1 front rotors w 16v sirroco calipers ( wich bolt on to a1 uprights)  and rears are 200x40 drums from a quantem , a2 jettas use 'em too. I'm switching to a 22mm master cyl to get a harder pedal..... :) w audi rolla 14in rims
'81 Frankenbunny: part rabbit, sirroco, golf ,caddy cabrio ,jedda and ! ford teimpo! w a little more Audi and soon some Peogeot too!!!!
Reply #2December 23, 2006, 08:37:06 pm
somolovitch3
  • 290
« Reply #2 on: December 23, 2006, 08:37:06 pm »
:? Okay, how about I grab the front brakes, disks, hub, calipers. et all; same with rear drum setup (Down to stubies) from a 85 Audi 4000? :twisted:
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
