Author Topic: Voltage Stabilizer  (Read 3836 times)
November 24, 2006, 11:04:55 pm
somolovitch3
  • 290
Voltage Stabilizer
« on: November 24, 2006, 11:04:55 pm »
:? Hey, anyone knows what the output of the voltage stabilizer ( the three legged IC Chip looking thing on the back of the dash's PC Board) is supposed to be? This is the supply for the water and fuel guages.
Thanks!
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #1November 24, 2006, 11:33:31 pm
QuickTD
  • 1156
Voltage Stabilizer
« Reply #1 on: November 24, 2006, 11:33:31 pm »
I don't know, never seen one before, but it sounds like a standard voltage regulator IC. I may be able to determine the output voltage from the part number, what number is printed on the case? Some "normal" numbers are LM7805 or LM340-T5 which are both 5 volt output.
Reply #2November 25, 2006, 07:25:05 pm
somolovitch3
  • 290
Voltage Stabilizer
« Reply #2 on: November 25, 2006, 07:25:05 pm »
:twisted: It is an ITT chip, the closest thing that comes up is an audio amp. I know that it is less than 12 volts, just do not know how much less. Searching the web got me to a site for a '83 Vanagen, which said "10.5 to 11.5 volts". Does not sound stabilized to me. I know that the voltage "Viberater" in American cars put out 5 or 7 volts, but what does my '81 Caddy wish for?  Any help would be nice!
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
