Author Topic: safe mode stereo  (Read 4818 times)
November 12, 2006, 12:37:34 pm
SMOKEYDUB
  • 630
safe mode stereo
« on: November 12, 2006, 12:37:34 pm »
Ok well my battery died in my 95 passat idi, now the stereo is in safe mode. Can i get the stereo out of safe mode? Anything easy i can do or should i just dump in an aftermarket one?
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #1November 12, 2006, 06:17:58 pm
wolfsburgnut
  • 126
safe mode stereo
« Reply #1 on: November 12, 2006, 06:17:58 pm »
If  you have the code there is a procedure for unlocking the radio.  Even if you don't have the code phone up the dealer and they should be able able to give it to you if it is the original radio in the car.  They just need your VIN.  Is it a heidelberg?
I found this info on it.
http://forum.ecoustics.com/bbs/messages/4/106673.html
Hope this helps.
Peter
1995 Golf 1.9
1994 Golf Marathon
1990 Golf 1.8
1986 Golf Wolfsburg Ed.
Reply #2November 12, 2006, 06:38:42 pm
Darkness_is_spreading
  • 288
« Reply #2 on: November 12, 2006, 06:38:42 pm »
I had the same radio de death mode...
Contact the VW dealer and they can open the radio up and pull out the code......
This is what I was told, maybe if you show me the radio I could pull the radio apart, and take the code to them., they may charge for the labour of getting to the code....
83 Jetta 1.9 T (Project Darkness)
88 Jetta 1.6 NA (Dead/Crushed)
92 Jetta 1.6 T (Sleepin)
96 Golf 1.9 T (Parts Car + Mexican Rust Bucket)
Reply #3November 12, 2006, 07:37:48 pm
andy2
safe mode stereo
« Reply #3 on: November 12, 2006, 07:37:48 pm »
sometimes the previous car owners write the code down in the owners manual or the radio manual,Worth checking??
Reply #4November 14, 2006, 06:18:22 pm
bvolks73
  • 183
safe mode stereo
« Reply #4 on: November 14, 2006, 06:18:22 pm »
I just picked up a used stereo from a 99 VW (or so the serial # tells me when i search it in google) at a local thrift store (where they take donations and resell them to help the needy) and can't get it out of safe mode. I called the dealer and they won't tell me anything unless I have the VIN and registration of the vehicle it came from, claiming that it also might be too old for them to be able to get at all. I'm going to post a message on the bulletin board at the place I got it from and hope the previous owner sees it and helps me out.
1985 TD Jetta coupe
1995 Golf CL
1971 VW Doublecab
1999 Corolla
2005 Sx 2.0
2007 Yaris
