Author Topic: Experts... oil filter question- no bypass  (Read 10185 times)
Reply #15November 05, 2006, 07:30:21 am
addautomotive
« Reply #15 on: November 05, 2006, 07:30:21 am »
Thanks fatmobile,
I think I remember seeing a description of your setup... to regulate ~10 psi, you use an oil pressure sender to switch a fuel pump or compressor off?
Reply #16November 07, 2006, 09:19:30 pm
  • 2931
oil filters
« Reply #16 on: November 07, 2006, 09:19:30 pm »
The original plan was to use a switch to shut the air compressor off when it got to 30psi...
 but I've been switching it manually, with a pressure relief valve for when I get busy and forget about it.
