Best fuel additive?
Topic: Best fuel additive? (Read 5555 times)
November 01, 2006, 11:20:11 am
larry104
Best fuel additive?
November 01, 2006, 11:20:11 am »
With the weather turning cold, and low-sulfur diesel fuel, which additive(s) would you guys recommend for a 1.6 TD? Thanks.
November 01, 2006, 11:30:09 am
Jetta Fan
Best fuel additive?
November 01, 2006, 11:30:09 am »
I'm using Howes, but just started in the last month or so.
I know a friend of mine likes Gen49.
I was looking at Kleen-Flo the other day, but don't know anyone using it, so I didn't buy it. (I'm almost out of the Howes I was given)
1997 Jetta 1.9TD AAZ
November 01, 2006, 12:27:20 pm
Justin
Best fuel additive?
November 01, 2006, 12:27:20 pm »
anything that adds viscosity and lubricity, hey wait a blend of B20 for the winter is just what I am doing. Higher blends in the summer. or higher blends in the winter in the heated fuel tank.
other than that I will toss in small amounts of filtered used veg oil and such. I hear avation oil is good since its very clean
www.archeryprostaffmi.com
November 01, 2006, 01:23:29 pm
Best fuel additive?
November 01, 2006, 01:23:29 pm »
I use the stuff from canadian tire. Thier own brand. I also will use 2-stoke oil or ATF. Actually I have some stuff too but I forget what it's called.
November 01, 2006, 02:33:40 pm
larry104
Best fuel additive?
November 01, 2006, 02:33:40 pm »
Thanks. Hmmm, nobody mentioned Stanadyne.
November 01, 2006, 07:33:26 pm
commuter boy
Best fuel additive?
November 01, 2006, 07:33:26 pm »
You only got replies for three hours. +1 for Stanadyne. I use bio these days as an additive, but break out the Stanadyne on new to me diesels to clean them out.
November 02, 2006, 06:23:35 am
VelocityConservation
Best fuel additive?
November 02, 2006, 06:23:35 am »
I use "diesel Source".
90 TD Jetta, NA to TD swap completed '07
November 02, 2006, 11:57:45 am
VWCaddy
Best fuel additive?
November 02, 2006, 11:57:45 am »
I use Stanadyne Performance Formula mixed with a pint of 2-stroke oil per tankfull of diesel.
'82 VW pickup, 1.9D engine,
Missing LinkZ shift linkage
November 02, 2006, 08:51:18 pm
philone
Newbie
Best fuel additive?
November 02, 2006, 08:51:18 pm »
I use the PowerService brand DieselKleen in the summer (gives +6 cetane boost) and the same brand DieselPower in the winter (has a good anti-gel as well as +3 cetane boost). I run it in my '86 NA as well as '06 TDI. Makes a big difference.
1986 Jetta Diesel Wolfsburg
November 02, 2006, 09:41:38 pm
Best fuel additive?
November 02, 2006, 09:41:38 pm »
agree on the power service. boosting the cetane numbers does make a difference, unlike boosting the octane number on gas which only gives less emissions on a vehicle that doesnt have high compression.
Best fuel additive?
