For Sale/Looking For
Parts for Sale/Wanted
Selling off my VE parts - Modified Cummins 12mm pump, etc.
Topic: Selling off my VE parts - Modified Cummins 12mm pump, etc. (Read 8910 times)
October 30, 2006, 08:19:09 pm
vwmike
Authorized Vendor
October 30, 2006, 08:19:09 pm »
So, I went and bought a PD150 so I don't really have anything to put this stuff on anymore. Basically I have a Cummins 4B injection pump which i've modified along with most of a mk3 TDI injection pump and a 12mm pump head conversion from Red Rotors.
Cummins pump - This was a BRAND NEW 4B injection pump that I bought some time ago and modified by adding an LDA from a Peugeot pump, governor assembly from a VW pump (with the governor mod already done), cut down VW timing piston so timing advance isn't limited, and a VW timing spring. It still has the Cummins 4B DI cam plate currently.
TDI Cam Plate - I bought this with the intention of putting the TDI injection pump I have back together with the 12mm pump head conversion I bought from Red Rotors. The only thing I think I'm missing from this setup would be the spring guides. You may want to swap this into the Cummins pump....that's up to you.
TDI Injection pump (mostly) - This is off of an AHU and right now is just sitting there without a pump head or cam plate. It has the timing spring and cover on it still which could be transferred onto the Cummins pump so that the advance curve would be the same. Again, that's up to you.
12mm pump head coversion - as I said earlier, I bought this from Red Rotors a long time ago and never ended up using it.
Also:
Peugeot 10mm injection pump - This pump is complete and used. I swapped one of these pump heads onto my Jetta TD a while back and the power gains were definitely there. This pump also has the LDA and everything.
I'm looking to sell this stuff or possibly some combination of the stuff. If you're interested then send me a message with what you want and I guess we can work out a price.
November 01, 2006, 05:41:41 am
fuslit
November 01, 2006, 05:41:41 am »
I think I am interested in the Cummings pump/12mm head/TDI Cam plate (and what ever else I would need to make a complete pump)
But I'm not sure if it is feasible to run this on a 1.6td I am building up right now. I do want to build a m-tdi later which it would work on, but so as not to clutter your for sale thread and to get other people's thoughts I made a new thread here
http://vwdiesel.net/phpBB/viewtopic.php?t=5440
Get in touch with me though and let me know what your looking to get for all the stuff with shipping. I'm located in Seneca Falls, NY 13148
Thanks
-Todd
'81 rabbit 4dr 1.6TD [project]
'98 jetta tdi [daily]
November 01, 2006, 02:37:18 pm
g-spec
November 01, 2006, 02:37:18 pm »
I would like more info on the 10mm head pump from the peugeot!!!
If you could email me more info:
[email protected]
thanks
Michal
November 01, 2006, 04:54:31 pm
vwmike
Authorized Vendor
November 01, 2006, 04:54:31 pm »
I'm sorry, I just received payment on the Peugeot pump so it is now sold.
The other stuff is still available though.
November 08, 2006, 01:11:03 am
vwmike
Authorized Vendor
November 08, 2006, 01:11:03 am »
Here's some pictures of the Cummins pump:
This is suitable for use on a TDI-M project. Check out this thread for more detail:
http://vwdiesel.net/phpBB/viewtopic.php?t=1956&highlight=mechanical+tdi+cumm
ins
I'm asking $600 OBO. Keep in mind the pump itself is still new and a genuine Cummins/Bosch part.
November 08, 2006, 07:09:51 pm
November 08, 2006, 07:09:51 pm »
cummins/1.6td hybrid pump is what hillfolk runs and he did a flat 14 with it
November 09, 2006, 08:50:29 am
RabbitGTDguy
November 09, 2006, 08:50:29 am »
for the mTDI setup using the cummins pump there is more to consider than what I just put in the thread you mentioned...just to protect your rear end. I didn't give out all the information on it.
Mines up an running GREAT with the cummins pump I made...however, as mentioned, there are other considerations before using the pump...
Hillfolks pump is def the VW TD base pump if I remember correctly, with the cummins 12mm head, etc. Its the small shaft pump and remains that but he hasn't had any problems that I've heard of...
Joe
1972 VW Westfalia
2001 Audi TT 225 Quattro Roadster (something newer
November 22, 2006, 01:20:21 am
vwmike
Authorized Vendor
November 22, 2006, 01:20:21 am »
The 12mm pump head conversion is sold. The Cummins pump is still available though!
December 12, 2006, 08:35:30 pm
Zeroroll
Newbie
Cummins pump
December 12, 2006, 08:35:30 pm »
I'm seriously considering the Cummins Pump.
I'm a little confused by RabbitGTDguy's post,though.
Is this ready to go,on a VW TDI engine, making it a TDI-M or does it require further internal work?
I currently have exactly what Hillfolk has...A 1.6 TD pump and a Cummins 4BT pump. Only difference is I haven't "melded" the two together yet. Hence my interest in this pump.
You may reply via email if you wish:
[email protected]
Thanks.
December 14, 2006, 11:04:10 am
vwmike
Authorized Vendor
December 14, 2006, 11:04:10 am »
I just responded to your PM.
December 14, 2006, 06:15:55 pm
Zeroroll
Newbie
Cummins Pump
December 14, 2006, 06:15:55 pm »
And I to yours.
Reply #11
December 15, 2006, 08:26:12 am
RabbitGTDguy
Reply #11 on:
December 15, 2006, 08:26:12 am »
and it sounds like you guys have worked it out...but yes, it does need a bit of internal work besides just the gov. assembly swap. You also have to configure your injection pump sprocket alignment as well...
Joe
1972 VW Westfalia
Reply #12
December 15, 2006, 09:06:07 am
vwmike
Authorized Vendor
Reply #12 on:
December 15, 2006, 09:06:07 am »
What other internal work would you advise? I had this pump completely torn down so I think I did everything necessary.
Reply #13
December 15, 2006, 04:07:28 pm
RabbitGTDguy
Reply #13 on:
December 15, 2006, 04:07:28 pm »
then you should be fine eh?
Good Luck in the sale! Looks like you've found a buyer
Joe
1972 VW Westfalia
Reply #14
December 15, 2006, 05:45:25 pm
Zeroroll
Newbie
Well...
Reply #14 on:
December 15, 2006, 05:45:25 pm »
Perhaps!
I'll be into the cost of having a 1.6 pulley machined to fit the larger shaft first.
I plan to take the pulley and a 4bt core pump to a few local machine shops for quotes.
