Author Topic: questions about springs.  (Read 4301 times)
October 30, 2006, 04:32:59 pm
mainer
  • 126
« on: October 30, 2006, 04:32:59 pm »
I'm looking to lifting my A3 up for winter. I currently have H&R sport springs in it, so its lowered. I've got the stock springs, but I figure that I'll take it to both extreams. I can use B3 passat springs in the rear to take it up. But what to do in the front? Its the same as a A2 as far at the struts are and everything. Would B3 springs work up front? Or could I use the complete B3 strut assembly?
Any Ideas?
Thanks Cooper
_________________
recession?
01 Jetta
84 Jetta TD
08 Duramax
12 Sportwagen TDi
Reply #1October 31, 2006, 05:11:22 am
Justin
  • 455
« Reply #1 on: October 31, 2006, 05:11:22 am »
get the front springs from a fully loaded with ac and powersteering cabriolet. that should do the trick for you.
www.archeryprostaffmi.com
Reply #2November 13, 2006, 04:04:01 pm
mainer
  • 126
« Reply #2 on: November 13, 2006, 04:04:01 pm »
What makes the Cabby any heaver? I was given a set of VR6 springs which should lift it about 2 inches, I think I'm just going to make a spacer to make the spring longer.
Cooper
_________________
u.s. recessions
01 Jetta
84 Jetta TD
08 Duramax
12 Sportwagen TDi
Reply #3November 14, 2006, 01:37:14 pm
MacGyver
  • 245
« Reply #3 on: November 14, 2006, 01:37:14 pm »
I've wanted to lift my A3 Jetta for a while, haven't got to it yet.
The B3 springs are similar to the A3 springs then? How much heavier or longer are they, and from wagon or sedan?
I know the B4 sedan rear ones are drastically different, I have a set of those & they've gotta be 6" longer & WAY heavier :shock:
The fronts are similar length & marginally heavier if at all.
I was considering using the fronts, with a spacer if necessary, and cutting the rears down coil by coil till I get my desired height. If they are to stiff/harsh, I'll perhaps make up spacers or extensions for the rears too.
On that note, how much of a lift over stock are you thinking, and any idea how far you can go without compromising the integrity or life of the CV's?
Reply #4November 15, 2006, 06:26:35 pm
mainer
  • 126
« Reply #4 on: November 15, 2006, 06:26:35 pm »
The b3 springs are longer and bigger. They lift it about 4 inches. I'm gonna cut them down and go for about 2.5 inches of lift.
_________________
Gossip Girl Forum
01 Jetta
84 Jetta TD
08 Duramax
12 Sportwagen TDi
