Author Topic: Audi TT transmission upgrade questions for a rabbit TDI  (Read 10272 times)
October 30, 2006, 05:07:47 am
Justin
  • 455
« on: October 30, 2006, 05:07:47 am »
hey guys I picked up a 2002 audi TT 6 speed awd unit. I need a few things to complete the swap like inner CV joints. does anyone know where I can get these?
or does anyone know if the TT outer cv joints have teh same splines for the hub as the rabbits? if so then I can just buy reman axles
also how does one remove the awd unit since I will not be using it.
last question does anyone know if this trans can be made to a cable clutch, if not what are you guys doing for setups for the hydrallic clutches?
thanks guys
Justin
www.archeryprostaffmi.com
Reply #1December 02, 2006, 03:07:53 pm
« Reply #1 on: December 02, 2006, 03:07:53 pm »
i think it is possible to go cable clutch with them some how,  i am going to guess though, that the 6 speed will be poo on the tdi... just a guess
Reply #2December 02, 2006, 04:00:45 pm
« Reply #2 on: December 02, 2006, 04:00:45 pm »
Quote from: Trev0rbr
Why's that? The gearing specifically or just having 6 gears? On TDIclub or somewhere I read about someone swapping in a 6th gear, he said it was well worth it and highly recommended it. It was on a mk4 TDI I think
Reply #3December 02, 2006, 06:36:58 pm
Justin
  • 455
« Reply #3 on: December 02, 2006, 06:36:58 pm »
Its because of the gear ratios. but I have everything figured out I traded the TT trans for a tdi one and all of the hydrallic clutch stuff so I will be good to go
Reply #4December 02, 2006, 09:37:54 pm
SMOKEYDUB
  • 630
« Reply #4 on: December 02, 2006, 09:37:54 pm »
1.8ts (jettas/golfs) came 6 speed it would be your best bet to do that. i would think it would bolt up to the tdi. that tt *** would be alot of hassle.
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #5December 03, 2006, 12:29:32 pm
Justin
  • 455
« Reply #5 on: December 03, 2006, 12:29:32 pm »
the only thing that would have been difficult with the TT trans would be routing the exhaust since the awd box was right in the way. the TT trans bolted up since it originally had a 1.8 T
but yes simpler is better.
later
Justin
Reply #6January 09, 2007, 02:39:10 am
DA-BRT
  • 140
    • http://Zwalve.eu/
« Reply #6 on: January 09, 2007, 02:39:10 am »
Nop they are the same as the ones from the VR6. You can use Scirocco 16v joints or from another older VW with 100mm inner joints.
I don't think you can take off the parts voor rear wheel drive. Or you have to weld you tranmission to get it closed again.
Goodluck.
Were now converting a Golf MK1 with an Audi A3 Quattro driveline. Also a 6-speed gearbox. (think almost the same as yours) Were completely taking over the rear axle and suspension. Lot of welding there. I'll post some pictures if anyone is interested.
Reply #7February 02, 2007, 12:37:20 pm
Justin
  • 455
« Reply #7 on: February 02, 2007, 12:37:20 pm »
can you post some pics
Reply #8February 02, 2007, 06:58:45 pm
« Reply #8 on: February 02, 2007, 06:58:45 pm »
Quote from: "Justin"
+1
Reply #9February 02, 2007, 07:23:11 pm
wolfsburgnut
  • 126
« Reply #9 on: February 02, 2007, 07:23:11 pm »
me three!!
1995 Golf 1.9
1994 Golf Marathon
1990 Golf 1.8
1986 Golf Wolfsburg Ed.
Reply #10March 02, 2007, 09:33:58 am
foxracer1
  • 991
« Reply #10 on: March 02, 2007, 09:33:58 am »
Me 4
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #11March 04, 2007, 06:11:24 am
« Reply #11 on: March 04, 2007, 06:11:24 am »
i've also read that the 6 speeds are alot larger and harder to fit into a mk1
Reply #12March 13, 2007, 12:13:18 pm
Justin
  • 455
« Reply #12 on: March 13, 2007, 12:13:18 pm »
I traded mine for a tdi trans because of gear ratios and clearance issues, I could have made it work but running the exhaust would have been a pain in the butt
later
Justin
