Author Topic: Need Audi 2.0TD info  (Read 9556 times)
October 22, 2006, 10:17:44 am
andy2
« on: October 22, 2006, 10:17:44 am »
I know someone who is planning on putting the old 2L td into a toyota.Does anyone have any experiences with how these engines hold up when the fuel and boost is turned up a bit.Also will the Vw 2.4L D headgasket work on the 2L Audi engine (like 1.6 upgraded to 1.9 steel HG)?Thanks for any replies :wink:
Reply #1October 23, 2006, 10:12:36 pm
itzdshtz
  • 94
« Reply #1 on: October 23, 2006, 10:12:36 pm »
I had a 1985 5000 TD for years and I sold it with about 400000 km on it.
The only modification I did on it was to raise the boost to 16 Psi and turned the fuel up a bit. Just before I sold it, I installed a new set of piston rings and bearings in it, but there was quite a bit of wear in the cylinders and it should have been rebored. The next owner drove it for at least another 3 years before selling it.
I am in the process of installing a 2.0 TD in a Vanagon Syncro, put oversize pistons in it and have rebuild everything else.
I am using a Saab intercooler and will be running around 18 psi boost.
The main problem with VW diesel piston wear is cold starts, so I have a pre-lube pump installed that brings the oil pressure up before starting.
The 2.4 D steel head gasket will fit, there is one extra oil return opening in it but it protrudes outside of the block and doesn't effect the sealing.
So IMHO don't set your boost too high, use an intercooler and if you let this engine warm up before you step on it, it will last a long time.
1989 Vanagon Westfalia 2.1
1987 Vanagon Syncro Westfalia 2.0 TD
2004 Audi allroad 4.2
1997 Audi A6
1985 Audi 5000 Td
http://vanagonsyncroproject-herman.blogspot.com/
http://picasaweb.google.com/itzdshtz/VanagonSyncroProject02
Reply #2October 24, 2006, 08:39:08 pm
Darkness_is_spreading
  • 288
« Reply #2 on: October 24, 2006, 08:39:08 pm »
If you use the starter to build up oil pressure in the 2.0,  would it also be beneficial to  build oil pressure in a 1.6 TD .   This could be for cold or warm temperatures.
I always build up pressure on my 1.6 TD after an oil change,  make sure the oil circulates effectively around the motor.  Then prime the GP and fire the motor.
Could this step add a few extra years to a motor, as well as running  either  Rotella T 15W40 or  15 W 40  full synthetic.
Also the 2.0 L diesel you talk about, is it 16 V.....
92 Jetta 1.6 T (Sleepin)
Reply #3October 24, 2006, 09:22:37 pm
jackbombay
  • 599
Re: ...
« Reply #3 on: October 24, 2006, 09:22:37 pm »
Quote from: Darkness_is_spreading
  No, 10V
Reply #4October 25, 2006, 09:31:41 am
houseofdiesel
  • 210
« Reply #4 on: October 25, 2006, 09:31:41 am »
Consider using head studs instead of bolts, warped heads were very common back in the day and make sure the cooling system is overdone! You can overcool and the thermostat will close, however overheat and game over. I also heard of oiling issues on one cylinder so consider prelubing as mentioned.
I don't think you will have very much torque compared with a Toyota diesel (are you doing a truck or Land Cruiser?) I have a 2.4 Toyota turbo diesel, HUGE amounts of torque compared to the Audi motor, without the turbo spooled the Audi motor is not that powerful, however the Toyota truck I have will move a few tons just using the clutch no throttle! Very different pump settings inside I think as the Toyota will fuel itself to keep idling were the Bosch pumps do not (stall out much quicker)
I am planning a couple of Audi quattro conversions with the 2.0 td over the next year or two and maybe even a 2.4 D24T conversion into something.
Greg
Reply #5October 25, 2006, 07:53:40 pm
andy2
« Reply #5 on: October 25, 2006, 07:53:40 pm »
Thanks for the info guys I'll relay it to him.He's putting the engine in place of a V6 gasser its definitely a newer toyota :oops: I'm not sure what the thing is called,You guys might know what I mean :lol:.
Reply #6October 26, 2006, 03:46:53 pm
Turbinepowered
  • 1206
« Reply #6 on: October 26, 2006, 03:46:53 pm »
I thought the 2.4L was an inline six, the 2.0L is a five. Head gasket has an extra hole? o_o
Reply #7October 26, 2006, 04:54:27 pm
itzdshtz
  • 94
« Reply #7 on: October 26, 2006, 04:54:27 pm »
Hi, the later 5 cyl. Diesel in the Canadian Eurovan is 2.4 ltr.(same displacement as the 6 cyl engine used in the Volvo)
It has a 79.5 bore x 95.5 stroke  compared with 76.5 bore x 86.4 stroke in the 2.0 TD.
The headgasket has an extra hole because this engine has hydraulic lifters, so there is more oil returning to the crank case.
1997 Audi A6
1985 Audi 5000 Td
Reply #8October 26, 2006, 06:54:51 pm
Turbinepowered
  • 1206
« Reply #8 on: October 26, 2006, 06:54:51 pm »
Ohhhhhhhhh... This I didn't know!
Hmmm...
Any chance an American with dreams could get one of these "later 5-cyl diesels" from Canada? I promise I won't buy cheap drugs from you guys and run up the subsidy costs... >.>
Ah. I didn't know about that one either, I was referring to the hole for cylinder #6! :p
Reply #9October 26, 2006, 07:00:58 pm
Slave2School
  • 531
« Reply #9 on: October 26, 2006, 07:00:58 pm »
Also keep in mind the 5cyl we got had no turbo :(  It was slow as sin in the Eurovan
2002 ford focme wagon
