General Information
Upgrades (non engine related )
Aftermarket stereo in '81 Rabbit
Topic: Aftermarket stereo in '81 Rabbit (Read 14057 times)
October 18, 2006, 05:31:25 pm
lacolocho
October 18, 2006, 05:31:25 pm »
What do I need to do to install a new aftermarket stereo with a standard 12-pin socket into my '81 Rabbit?
I know I need a connector or wiring harness or something, but what is it called? What is the old kind of connector called?
October 18, 2006, 05:34:04 pm
October 18, 2006, 05:34:04 pm »
Adaptor???
Mine was cut out and removed so I had to re-wire everything. Pretty simple
October 18, 2006, 11:16:06 pm
kx250crasher
Newbie
October 18, 2006, 11:16:06 pm »
Its really easy to install a stereo in a rabbit. I guess there might be an adapter you can buy. All you have to do is find a wire with constant 12v or run a wire from you battery. Then find a wire that supplys 12v when you turn your ignition switch on. Hook up your ground and all thats left to do then is connect your speaker wires and your wires to you amp, if your using an amp. Oh yea as far as I know there is no mounting kit, you have to cut the hole out for the stereo. Its simple it shoudnt take you more than an hour providing you allready have speaker wire ran.
81 rabbit 1.6 n/a w/ wvo conversion
81 caddy 1.6 n/a
82 rabbit 1.6 n/a
October 19, 2006, 07:51:57 am
macsdub
October 19, 2006, 07:51:57 am »
you got a couple of choices
as far as a power feed is concerned
you could hook to the stock wire,so you have key on/off power to the radio
or just run it to the fusebox+find a constant 12+ source
i like mine like that cause then i can run the stereo without the key being on
yea maybe you could find an adapter to plug right into the existing wiring
but id probably favor abandoning the stock wiring(dont cut it),and running all new wiring
i got a stereo rigged in my car in like 1.5 hours screwin around+taking my time
its an ugly install though
heck my car is ugly
most of the time this is hilfolk'r... ive forgotten my password
October 20, 2006, 09:32:02 am
clbanman
Cambridge, Ontario
Stereo install.
October 20, 2006, 09:32:02 am »
http://www.crutchfield.com/S-H3qnZh54qUg/cgi-bin/SuperProdGroup.asp?g=266150
to show what will fit your car. According to them, everything will need to be modified. I checked a few other sites, and all indications are that there is no adapter and you will have to cut your factory wiring and splice into it.
http://www.installer-data.com/aacars/car_data.php?carid=5576
shows a "universal" mounting plate.
Calvin
91 VW Golf 1.6NA 5spd
October 22, 2006, 07:34:33 am
macsdub
October 22, 2006, 07:34:33 am »
thats why id abandon the factory wiring,and start fresh+so you dont have to hack on the orig. wiring
December 05, 2006, 09:09:57 pm
sprstu
December 05, 2006, 09:09:57 pm »
http://www.crutchfield.com/S-HenfrWdx79k/cgi-bin/ProdView.asp?g=103000&I=120701618
this is the wire adaptor that crutchfield offers
Mk1 caddy TD, mk4 Golf Tdi
December 06, 2006, 07:22:42 am
clbanman
Cambridge, Ontario
December 06, 2006, 07:22:42 am »
For some reason, if you log in your vehicle as a 1981 Rabbit and open your link, it says it does not fit that car. Will it actually fit or is it just a generic VW harness?
Calvin
December 16, 2006, 11:14:01 am
VWCaddy
December 16, 2006, 11:14:01 am »
I put an AM/FM/CB/Cassette radio in my '82:
http://www.4crawler.com/Diesel/CheapTricks/index.shtml#CBAntennaMounting
'82 VW pickup, 1.9D engine,
Missing LinkZ shift linkage
General Information
