Author Topic: Pre winter clean up sale...1.9 AAZ stuff (LOTS)  (Read 5004 times)
October 16, 2006, 07:15:10 am
houseofdiesel
  • 210
« on: October 16, 2006, 07:15:10 am »
Okay, so I am cleaning up for winter now and have a bit too much to store...I am not selling cheap as this stuff is hard to find and will always be in demand locally with the number of diesels around- Iam not taking offers!
CDN funds listed plus shipping, I am near Ottawa
1.9 AAZ block with new rings and rod bearings, good crank nose $500
1.9 block with revised crank noise on lathe, new bearings throughout, rings etc $750
SOLD1.9 AAZ long block 250000kms, valve cover to oil pan nothing else, condition still unknown $1000 will test if serious interest
1.9 injection pump, running this week not leaking from 93 Passat $300
1.9 valve covers $30
1.9 alternator bracket $150 with new bushings
1.9 alternator I have 70 or 90 amp choices $100 each
1.9 k14 turbo $150
1.9 downpipe one piece with cat, kidney shaped at turbo $120
1.9 downpipe, square flange at turbo with new flex section, flanged for replacement cat $150
1.9 p/s pump fits all mk3 4 cyl cars $50
1.9 block with damaged cylinder/piston, crank nose has TDI gear $100
1.9 golf/jetta turbo intake hose $50
1.9 air box assembly $30
1.9 crank serpentine pulley in mint shape (new design) $100
1.9 engine brackets, rear mount,  front mount, front subframe, rad support,
1.9 clutch assmbly with flywheel $50
Used glow plugs, working fine $10/4
Please serious only, I don't have time to reply to tire kickers right now. I don't have pics, you should know what this stuff looks like, it is all 1.9 AAZ stuff.
Reply #1October 16, 2006, 11:52:10 am
commuter boy
  • 277
« Reply #1 on: October 16, 2006, 11:52:10 am »
How close is the Golf/Jetta airbox and intake to the Passat ones?
Reply #2October 16, 2006, 01:13:11 pm
Justin
  • 455
« Reply #2 on: October 16, 2006, 01:13:11 pm »
I am interested in the Clutch setup along with the valve cover. does the valve cover work on the early TDI's?
Let me know
Justin
www.archeryprostaffmi.com
Reply #3October 16, 2006, 01:33:54 pm
houseofdiesel
  • 210
« Reply #3 on: October 16, 2006, 01:33:54 pm »
Valve cover is not similar-the AAZ has straight edges while the TDI one has "ribs" along the front edges.
I will dig up the clutch set up and weight it.
Air boxes are different on Passat same for turbo intake hose, not sure what is different.
Greg
Reply #4October 17, 2006, 09:44:39 am
Justin
  • 455
« Reply #4 on: October 17, 2006, 09:44:39 am »
houseofdiesel,
could you email me some pictures of the clutch setup that you have?
my email is [email protected]
thanks
Justin
Reply #5October 17, 2006, 03:02:18 pm
scopefrfd
  • 289
« Reply #5 on: October 17, 2006, 03:02:18 pm »
interested in a bunch of parts...please PM
Reply #6November 08, 2006, 08:58:13 am
houseofdiesel
  • 210
« Reply #6 on: November 08, 2006, 08:58:13 am »
okay up again I am back from a short break to catch some sleep and relax...
I sold one long block otherwise everything is still here, plus I have collected some more to sort through yet...
