Author Topic: Low water indicator  (Read 5670 times)
October 10, 2006, 04:01:58 pm
Powjetta
  • 152
    San Diego CA
Low water indicator
« on: October 10, 2006, 04:01:58 pm »
My light has started blinking at random times and as the coolant is very important I want to eliminate the false alarms.  It seemed to work good until I changed coolant and I put the blue VW antifreeze in with a little water wetter.  Is this mixture some how not conductive or is there some other trick to make this work?  Anybody else have this problem?
'86 jetta 2 dr Turbo diesel K24 - sold
'94 GMC 6.56TD - sold
Reply #1October 10, 2006, 06:20:05 pm
insdtanoodles
  • 148
Low water indicator
« Reply #1 on: October 10, 2006, 06:20:05 pm »
im having this problem as well, I just though that the level sensor in the expansion tank went bad so I was going to replace the tank.
1996 vw jetta AAZ
Reply #2October 11, 2006, 03:21:12 am
Doug
Level float
« Reply #2 on: October 11, 2006, 03:21:12 am »
Try washing the tank out with hot water and dish soap. Have seen it jam before with contaminants from the cooling sytem only to be freed up by washing. You will probably have to remove the expansion tank to your laundry room sink to do this properly.
Reply #3October 15, 2006, 07:46:27 pm
insdtanoodles
  • 148
Re: Level float
« Reply #3 on: October 15, 2006, 07:46:27 pm »
Quote from: Doug
did this today, still get the low coolant light but using an sos pad on the outside really cleans it up, now I can actually see how much coolant is in there.
1996 vw jetta AAZ
Reply #4October 30, 2006, 03:12:24 pm
Turbinepowered
  • 1206
Low water indicator
« Reply #4 on: October 30, 2006, 03:12:24 pm »
This is a common problem on the Quantum cars, from what I understand, common enough for it to be labelled the "Infamous Blinking Light" (IBL).
One member on another board/list traced the source of the IBL to an intermittantly faulty ground connection; he cleaned the connection, put a little dielectric on it, and hasn't had a false blinker since.
Reply #5January 02, 2007, 01:26:51 pm
Powjetta
  • 152
    San Diego CA
Low water indicator
« Reply #5 on: January 02, 2007, 01:26:51 pm »
I think it is the connection, after cleaning it the third time I realized there shouldn't be any coolant making it's way to that spot and I am trying to seal it up.
