General Information
General
Giles pump guys quick question for you
Topic: Giles pump guys quick question for you (Read 4173 times)
October 10, 2006, 10:11:15 pm
Justin
October 10, 2006, 10:11:15 pm »
for those whom have purchased the infamous injection pumps from Giles what do you set the timing at on your diesels?
also do you still use the cold start lever and if so when the vehicle is idle does it take much force to pull the cold start lever?
thanks in advance
Justin
www.archeryprostaffmi.com
October 10, 2006, 11:06:20 pm
October 10, 2006, 11:06:20 pm »
i dont have a giles pump, but it doesnt take any force to pull the cold start lever when the engine is running. sometimes the cable gets gummed up i suppose... i would use a graphite lube to loosen it up... oil just gets gummy after a while
October 10, 2006, 04:53:22 pm
SMOKEYDUB
October 10, 2006, 04:53:22 pm »
i just set my pump timing at 1 mm like the factory asks and doesnt really take much force to pull the cold start lever.
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
October 10, 2006, 05:29:16 pm
andy2
October 10, 2006, 05:29:16 pm »
On my Giles pump both the cold start advance and fast idle were dissabled possibly he's done the same to yours I don't know,call him!
General Information
General
