Where to find downpipe flanges?
Topic: Where to find downpipe flanges? (Read 4864 times)
October 10, 2006, 06:19:55 pm
Spulen81
October 10, 2006, 06:19:55 pm »
I'm putting at TD Garrett turbo on my TDI and need to make a downpipe. Are there square downpipe flanges available anywhere? Finding one already made would save me a ton of time.
'86 4Runner TDI SOLD
'91 GTI - TDI converted
October 10, 2006, 06:29:41 pm
saurkraut
October 10, 2006, 06:29:41 pm »
Get a gasket for the flange you want and go to a couple machine shops in your immediate area. Some may be reasonable on price.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
'86 Audi 5000 Turbo Quatro Wagon
92 Audi 100
'93 Eurovan
'82 Porsche 930
October 10, 2006, 07:37:21 pm
Spulen81
October 10, 2006, 07:37:21 pm »
That is true. I was hopeing somebody already made these.
October 10, 2006, 11:23:34 pm
veeman
October 10, 2006, 11:23:34 pm »
Yep... These are readily available. I got mine from an ATP dealer near me.
http://www.atpturbo.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=tp&Product_Code=ATP-FLS-018&Category_Code=BCS
Should be part no. ATP-FLS-018, but double check that it matches your turbo.
I looked for a guy locally to make me one, but he said it'd be well over $100 by the time he tooled up and did it. Whoa. I'll take the $20 pre-cut flange.
81 Caddy TD
98 Audi A4 Quattro V6 TDI
83 VW GTI FSP
86 4ktq
October 11, 2006, 12:36:33 am
Spulen81
October 11, 2006, 12:36:33 am »
Mine has a square 4 bolt pattern on the turbine housing. Its a T3 but I think the KKK turbo has the same exhaust pattern. I wonder if any of the square ones they have online would fit?
October 11, 2006, 12:58:07 am
veeman
October 11, 2006, 12:58:07 am »
You could always try these guys...
http://www.034motorsport.com/product_info.php?products_id=325
I know the owners of the company... good guys, mostly into high-powered Audi 5 cyl engines, but they should have the flanges you're looking for. If the one above isn't the right type, do a search for "flange" on that site and see what else they stock.
Do you have a stock downpipe from that turbo that you could use / measure the flange off of?
81 Caddy TD
83 VW GTI FSP
86 4ktq
October 11, 2006, 02:27:51 am
935racer
October 11, 2006, 02:27:51 am »
I sell them for $15CAd a piece.
October 10, 2006, 06:00:34 pm
HarryMann
October 10, 2006, 06:00:34 pm »
Can I butt in here please? Along the same lines, sortof...
Manifold to turbo joints...
To gasket or not, not that I can get one anyway!
I have been surface flatting both manifold face and turbo face to quite a high accuracy, as no gasket there originally, and I've tried as best to match the port sections, quite amazed how much these are out. (Garrett T2, joint that the 4 high strength flanged cap screws go through)
Do most just fit these up metal to metal to keep heat transfer even and a simple joint.
Is a thin smear of exhaust cement OK
Or is a gasket recommended and if so, which style, I don't like some I've seen at all.
Think those screws torque up to about 45 ft-lbs?
Thanks
PS. I'd get a flange laser cut from 3/8" minimim steel blanks, make a good template but allow the port to be fractionally undersize fro matching up later.
October 11, 2006, 05:02:03 am
Spulen81
October 11, 2006, 05:02:03 am »
You have email. That will difinetly make things easier.
October 11, 2006, 09:06:17 pm
macsdub
October 11, 2006, 09:06:17 pm »
either that,or hack the orig flange from the downpipe to weld on a custom d/p
ive dont that a few times in a pinch
and they are nice+thick
most of the time this is hilfolk'r... ive forgotten my password
October 12, 2006, 11:53:19 am
Spulen81
October 12, 2006, 11:53:19 am »
I thought about that but is it difficult to weld to the cast iron?
Reply #11
October 12, 2006, 12:42:49 pm
935racer
Reply #11 on:
October 12, 2006, 12:42:49 pm »
Welding cast iron is a little more difficult, and it is even harder if you are trying to get to hold under heat and vibration, like a downpipe.
Reply #12
October 12, 2006, 06:00:36 pm
HarryMann
Reply #12 on:
October 12, 2006, 06:00:36 pm »
G. Cast Iron - thin or thick
Weld in the flat position if possible. Out of position will require additional practice. Use JOF neutral flame. Use proper rod and high heat flux. Must preheat metal. Gring crack out. Heat rod and stick in flux. Heat metal and apply rod to molten metal. Penetration of welding rod is controlled by the amount of heat on molten puddle. (longer heating in molten puddle will give more rod penetration). Must postheat all of cast 4-600 degrees and let cool slowly. (Put sand, lime, etc., if possible. If cast rod is used you can drill, tap, or gring weld area.
