Author Topic: glow plugs for TDI  (Read 4959 times)
October 05, 2006, 10:17:56 am
naturalwv
  • 4
glow plugs for TDI
« on: October 05, 2006, 10:17:56 am »
I have a Golf TDI and need to replace a glow plug.  How can I tell which glow plug is bad?  How can I tell if I have a BEW or ALH engine code?  How hard is it to replace a glow plug?
Thanks,
Roger
Reply #1October 06, 2006, 06:00:47 am
Slave2School
  • 531
glow plugs for TDI
« Reply #1 on: October 06, 2006, 06:00:47 am »
You should fill in your profile a bit so we can help you.  The year of the car is important.
You can tell what one is bad through a resistance check, could also be the harness, the yare prone to corrossion.
2002 ford focme wagon
Reply #2October 06, 2006, 07:59:57 am
macsdub
  • 165
glow plugs for TDI
« Reply #2 on: October 06, 2006, 07:59:57 am »
yea resistance check is good or if you are a little "rocks+sticks "like me
then,take a test light,and hook one end to batt+,and with the glow harness removed from the plugs,just touch the tip of the plug in the head
you get a light,its good
no light,its bad
most of the time this is hilfolk'r... ive forgotten my password
Reply #3October 13, 2006, 06:32:39 am
glow plugs for TDI
« Reply #3 on: October 13, 2006, 06:32:39 am »
Quote from: macsdub
no light,its bad
yep that's how i do mine, some people say that they may still make a light work, that's when the resistance check is good, but i have never seen one that lit the test light and had a strange resistance reading.  you can also check by cycling ur glow plugs then feeling to see which ones are warm
Reply #4October 13, 2006, 07:29:01 am
Slave2School
  • 531
glow plugs for TDI
« Reply #4 on: October 13, 2006, 07:29:01 am »
I've also heard that it is good to replace them all at the same time since they are run in parallel (I think) and this would mean one or more would be hotter than others depending on the resistance.
Reply #5October 13, 2006, 08:40:06 am
macsdub
  • 165
glow plugs for TDI
« Reply #5 on: October 13, 2006, 08:40:06 am »
i know on power stroke fords the older the plugs get
,they can start to "short" and draw too much current and toast up the glow plug harness that goes thru the v/c gaskets,what crap
yea maybe changing as a set is a good idea,but the tdi is so easy,you can change 1 at a time
