Oil filter conversion kit
Topic: Oil filter conversion kit (Read 7673 times)
October 03, 2006, 09:32:27 pm
October 03, 2006, 09:32:27 pm »
Would love to see a conversion kit to switch to the newer style TDI filters like these:
http://cgi.ebay.com/ebaymotors/VW-Beetle-Jetta-Passat-Golf-Diesel-Oil-Filter-lot-of-4_W0QQitemZ180034664122QQihZ008QQcategoryZ33661QQrdZ1QQcmdZViewItem#ebayphotohosting
I know the newer style engines use cartridge style filters like these, and are easily accessible by unscrewing a cap and lifting them out of the motor (no oil is lost btw) makes it good for synthetic filter changes!
would probably be really expensive to implement, but just curious...
How can this be fitted to my 1.6 :lol: :
http://cgi.ebay.com/ebaymotors/VW-TDI-1-9-ALH-Oil-Filter-Bracket-and-Cooler-NEW_W0QQitemZ200033874550QQihZ010QQcategoryZ46095QQssPageNameZWDVWQQrdZ1QQcmdZViewItem#ebayphotohosting
October 03, 2006, 11:44:28 pm
October 03, 2006, 11:44:28 pm »
looks like it could work... would be such an awesome upgrade...!!!
October 03, 2006, 11:49:42 pm
zagarus
October 03, 2006, 11:49:42 pm »
you have my approval to pioneer it.
Project 1.9TD Jetta Coupe Completed. Back in action!
October 04, 2006, 06:40:53 am
veeman
October 04, 2006, 06:40:53 am »
Out of curiousity... what are the benefits of going with the TDI setup? Do you suspect a filtration problem with the "old" style filter?
The IDI filter is quite a bit bigger than the normal oil filters for gas cars of the same years and interestingly enough is now the standard part for all 1.8T's with the north-south engine (Audi A4 / Passat, etc). I believe they did this after the "sludging" incidents. That tells me that VW/Audi still trust that filter....
81 Caddy TD
98 Audi A4 Quattro V6 TDI
83 VW GTI FSP
86 4ktq
October 04, 2006, 07:42:31 am
saurkraut
October 04, 2006, 07:42:31 am »
I concur, I'd like to know the bennifit.
I have not witnessed a VW diesel oil filter plugged with soot. I suppose there are some out there that have never been changed, but the oil would probably be as thick as tar from soot contamination. I doubt the filter is able to trap much soot. Yes, the filter element is black, but its not successfully removeing the majority of the soot. The soot particles are too small.
It is the job of the oil to suspend and break down the soot particles so they don't adveresly affect the engine.
There were a lot of folks on Fred's page that were running a bypass filter that would remove soot. As I recall, it was a sepperate system that used a roll of toilet paper to do the filtering. You might want to visit Fred's TDi page and see if these filters are still being used.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
'86 Audi 5000 Turbo Quatro Wagon
92 Audi 100
'93 Eurovan
'82 Porsche 930
October 04, 2006, 10:13:14 am
October 04, 2006, 10:13:14 am »
the benefits my friends, is for quick and easy filter changes while running synthetic motor oil :twisted: no more quick and dirty filter changes, and having to add a qt of oil while doing it! after changing my girlfriend's filter on her 03 grand am (I had to force her to use synthetic... women...) I was in love with the filter cartridge. Just unscrew the cap, pull out (be careful not to drop any dirt in there) and replace with a good new one. Didn't lose much oil if any... just that which was stuck to the actual filter media, and a little bit is kept in the center of the cartrige, but much much less loss than with our filters.
Now... if its going to be a pain to install, then forget it. I was just wondering how easy it would be to retrofit this style system.
Another benefit could be the placement of the oil cooler. It looks as if it would be quite easy to install a remote oil cooler with thermostatic valves.
Best of both worlds, you get the fast warmups when cold, plus it cools your oil when you're having fun :twisted:
Does anyone have a pic of the oil filter mount on a 1.6TD by chance??? The listing says it will fit an ALH motor, so I'm guessing it wont fit. Will the filter housing from an AHU work???
October 04, 2006, 11:22:23 am
saurkraut
October 04, 2006, 11:22:23 am »
I guess I'm not convinced it is safe to run extended drain intervals on the IDI motors, unless you used one of those TP bypass filters to take the soot out. There were some strong supporters for those filters on the TDi page a while back.
Is there anyone who has had an oil analysis done on a 1.6TD running the crappy fuel we get over here, and had acceptable levels of soot contamination after a couple of thousand miles?
Maybe when we get the low sulfer diesel fuel, our soot levels will drop too.
I guess the choice is dribbling sooty oil over top of your radiator support, or dropping the mess out the bottom as it is now.
The existing 1.6td oil filter fixture on the block has the same oil cooler that the TDi one does, and it will also accept a therostatically cotrolled remote cooler as well. The TDi one might also make things a little too cosy betwwen the block and the radiator fan shrowd on the MK1 chassis.
Given the choice of changing synthetic oil regularly around 3K miles, or running longer and have to do a rebuild earlier is an individal choice. Having done a few full rebuilds, I'll dump my synthetic at 3K instead.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
October 04, 2006, 02:04:24 pm
October 04, 2006, 02:04:24 pm »
well with the recent change to ultra low sulphur diesel, it is hard to make my car smoke anymore. It will still make smoke, but not nearly as bad as before. Still need to get my pump seals fixed though.. it leaks pretty bad.
I, along with others, would agree that 10'000km oil change interval on a decent synthetic motor oil is possible. oil filter changes should be mandatory at 5000km though. this 'mod' would just make it easier to change the filter, and that is all. Oh and not to mention that the newer filters are a bit less expensive, larger overall, and contain newer technology to filter the oil for less soot in the oil.
October 04, 2006, 04:51:06 pm
macsdub
October 04, 2006, 04:51:06 pm »
what about this setup??
i recommend watching their videos,it seems impressive
http://www.fs2500.com/
most of the time this is hilfolk'r... ive forgotten my password
October 04, 2006, 05:53:59 pm
Kudagra
October 04, 2006, 05:53:59 pm »
thats funny they are just down the road from me. I might have to look into it
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
October 04, 2006, 05:58:07 pm
October 04, 2006, 05:58:07 pm »
I'm sold. I need this!!! Could probably get 25'000km out of an oil change
Reply #11
October 04, 2006, 06:56:16 pm
Reply #11 on:
October 04, 2006, 06:56:16 pm »
theres a guy on ebay selling the kit for $499. but for a cummins diesel engine.
I wonder if there would be any kits to connect it up to our vehicles? I guess it couldn't be that hard to swap in..
so yea theres guys with big rigs getting 60'000km oil change intervals with good oil samples... wtf??? that means our dinky diesel engines could get about... 100'000km+!!!!!!!!!!!!!!! $499 is nothing compared to the savings, and reduced engine wear.
Reply #12
October 04, 2006, 07:00:58 pm
Reply #12 on:
October 04, 2006, 07:00:58 pm »
wait... ok I found it here:
http://cgi.ebay.com/ebaymotors/Filtration-Solutions-FS-2500-bypass-filter-system_W0QQcmdZViewItemQQcategoryZ33661QQihZ008QQitemZ180034961052QQrdZ1QQsspagenameZWDVW
$190 USD for just the filter. oil lines etc we can find those for ourselves. This is one mean setup... I'm buying one asap.
Reply #13
October 04, 2006, 07:01:52 pm
Reply #13 on:
October 04, 2006, 07:01:52 pm »
Get a oil cooler adapter plate (for a real oil cooler, not the stock TD one) and hook up the lines, should be easy to make work
Reply #14
October 05, 2006, 12:45:31 am
macsdub
Reply #14 on:
October 05, 2006, 12:45:31 am »
my dad was wonderin how to fit one up on his 03 tdi golf
is there taps on the filter pad(i know,i know,its a carteridge)
i could use one too with my soot blower
hey that dude that lives nearby the fs 2500,,check em out+let us know.......... :wink:
