Cam pulley: red loctite or blue?
Topic: Cam pulley: red loctite or blue? (Read 2841 times)
October 03, 2006, 11:59:12 am
jantd
User+
October 03, 2006, 11:59:12 am »
Hi guys,
a quick last question about mounting my cam pulley of my 1.9td,AAZ..
I torqued to 45lbs.ft, rewhacked it,and for safety am gonna put the RED loctite on it. It's a M12 bolt of 40mm long though, and a friend of mine said I was never gonna get that loose anymore
and should use the blue loctite.Has anyone put red loctite on it already and loosened afterwarts- also:should I apply it over the whole length? :?:
thanks a million
Jan
October 03, 2006, 01:00:10 pm
saurkraut
October 03, 2006, 01:00:10 pm »
I use nothing on the cam bolt. Torque to the bently spec. and then a hammer tweek on a combination wrench.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
'86 Audi 5000 Turbo Quatro Wagon
92 Audi 100
'93 Eurovan
'82 Porsche 930
October 03, 2006, 01:53:31 pm
monst
October 03, 2006, 01:53:31 pm »
Yeah, I don't put any lock tite on either.......
The Cam is tapered. It is not really the
bolt that holds it on...... Granted I wouldn't
run around without the bolt....
Do you guys use locktite on aluminum :?:
I was told (so how somewhere cnat remember where)
that is was a bad idea to use it on aluminum...
Something to do with when you remove the bolt
that had locktite on it, it can strip the trhead...
what do you htink? :shock: :? :roll: :wink:
Jetta A2 91 1.6L Naturally Asthmatic....
Bosal header 2.25" exhaust Flomaster
October 03, 2006, 07:37:42 pm
insdtanoodles
October 03, 2006, 07:37:42 pm »
I dont know about blue but if you put red on there it would never come off... ever, even if you needed it to. Would have to heat it up to break down the red loctite and too much heat would start to anneal the cam.
1996 vw jetta AAZ
October 03, 2006, 07:49:42 pm
SMOKEYDUB
October 03, 2006, 07:49:42 pm »
blue loctite is good it holds nice and with a bit of effort it will come off red you have to heat up. the best thing to do is go by the book. adding any lubricant (loctite in its liquid form) will change the torque numbers.
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
October 03, 2006, 08:24:55 pm
macsdub
October 03, 2006, 08:24:55 pm »
locktite can be corrosive
just do it dry
and yea if you did use red,it would loosen up with heat from a propanre torch+that wouldnt ruin the cam,it wont get hot enough with propane
propane is pretty "safe" in that respect,the acetylene can get you too hot+warp+ruin stuff
most of the time this is hilfolk'r... ive forgotten my password
October 03, 2006, 08:26:49 pm
935racer
October 03, 2006, 08:26:49 pm »
DO NOT use loctite on the camshaft sprocket or bolt.
