Author Topic: 1.6TD intercooler piping diameter  (Read 8640 times)
Reply #15October 16, 2006, 08:30:39 am
g-spec
  • 289
« Reply #15 on: October 16, 2006, 08:30:39 am »
I am able to get around duty fees and shipping to canada....i have an address in the US.
I think i will go ahead and buy it...ill let you guys know how it turns out!!!
Reply #16October 16, 2006, 11:11:09 am
veeman
  • 421
« Reply #16 on: October 16, 2006, 11:11:09 am »
Well, I did some measuring and it appears that the garrett turbo outlet is just about 2" in OD / slightly larger than 1.75" ID.  The intake  "spigot"  is just over 1.75" as well...
I'm opting for 2" piping for my setup.  I figure it'll keep the ID roughly diameter constant  from turbo to intake and hopefully keep velocity up.  Should be easier to squeeze into the mk1 as well...
I'm using a Mitsubishi Starion / Conquest TSI intercooler with modified end tanks.  Should work pretty well, all metal design and it was cheap on ebay ($40).
I had the option of doing stainless piping, but I went with 2" mandrel bends from Summit instead.  At $15 each, the bends are cheap and I'll be able to wrinkle coat them just like my valve cover and the timing belt cover.  I did have to order an aluminum  2" mandrel bend to redo the intercooler inlet/outlet, but that was around $30 for a quality 6061 piece (I've heard the ones on ebay are suspect / low quality).
The only thing I've got left is the silicone couplers and I won't know which ones I need until we start fabbing it up.  Anyone got a source for cheap (but quality) silicone hoses?  Some of those things can be $30-40 each.
81 Caddy TD
98 Audi A4 Quattro V6 TDI
83 VW GTI FSP
86 4ktq
