Author Topic: D injector tester  (Read 3986 times)
September 19, 2006, 03:16:20 pm
snakemaster
  • 405
D injector tester
« on: September 19, 2006, 03:16:20 pm »
i was thinking of making a injector tester ie what thay pop at , and was thinking of making one out of a brake master cilinder bolted to a bit of steel with a bar as a lever but not shure if it will make the psi , what do you think?
Reply #1September 19, 2006, 11:09:49 pm
LeeG
  • 401
D injector tester
« Reply #1 on: September 19, 2006, 11:09:49 pm »
A master cylinder will make plenty of pressure, but you will need a sturdy mount and lever for it to be able to generate enough pressure as the master has a fairly large piston.
The much smaller piston in a bottle jack will develop the pressure more easily.
There are a few threads on here on homemade pop testers, mostly using bottle jacks.
'97 Passat TDI
Reply #2September 21, 2006, 01:28:03 am
  • 2931
break pressure tester
« Reply #2 on: September 21, 2006, 01:28:03 am »
I was thinking about this too... but would have to test them using brake fluid because using diesel fuel would destroy the seals.
Reply #3September 21, 2006, 02:21:14 am
Reply #4September 21, 2006, 02:51:54 am
snakemaster
  • 405
D injector tester
« Reply #4 on: September 21, 2006, 02:51:54 am »
nice one i think i will go down the bottle jack road and happy pumping :lol:
