Author Topic: LDA on an NA Pump?  (Read 16005 times)
Reply #30February 24, 2008, 05:50:23 pm
dillenger1
  • 777
LDA on an NA Pump?
« Reply #30 on: February 24, 2008, 05:50:23 pm »
I dont know that metals got balls of steel! :D Its super hard.I think pressing it out from the inside would be easier(less messy to)If you can get past the fly weights in the way.Maybe tapping it out from the inside out.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #31February 26, 2008, 10:09:04 am
dillenger1
  • 777
LDA on an NA Pump?
« Reply #31 on: February 26, 2008, 10:09:04 am »
bump :) Ok quik question about the LDA lever that comes down to act on the gov. plate.I was playing around with the action abit,and it seems very rigid.Is this correct?Its tight enough to make an indent in my fingertip before it moves.
Reply #32February 26, 2008, 10:59:43 am
rabbitman
  • 2788
LDA on an NA Pump?
« Reply #32 on: February 26, 2008, 10:59:43 am »
Yes, I wondered that to. I tried wrapping my brain around it 'cause I wanna know how it works but it's awful confusing. If you look down behind the....wait now, I just reread yer post. You mean the little movable throttle stop? I never pushed on that 'cause I thought it would break. Look on the LDA below were the turbo boost line hooks up and you'll see a little thing with a hole in it, it's the vent for the LDA. You can suck on it and it'll pull the diaphram down simulating boost, then you can feel the little lever move a tiny bit.
Reply #33February 29, 2008, 07:08:46 pm
dillenger1
  • 777
LDA on an NA Pump?
« Reply #33 on: February 29, 2008, 07:08:46 pm »
HA ha ,ive successfully pushed the post out of the way of the gov. plate! :D Its was easy enough with a propane torch and a punch after i took a die ginder to the little crimp on the outside ive got pics ill post soon.
Reply #34February 29, 2008, 07:23:16 pm
diffdude
  • 39
LDA on an NA Pump?
« Reply #34 on: February 29, 2008, 07:23:16 pm »
Cool, Glad to see it worked for you too.
81 caddy 1.6 td, 2.5" turbo back, snow performance water/meth injection, and all the other usual mods.
Reply #35March 03, 2008, 02:26:59 pm
dillenger1
  • 777
LDA on an NA Pump?
« Reply #35 on: March 03, 2008, 02:26:59 pm »
heres the post tapped back
Reply #36March 03, 2008, 05:30:34 pm
rabbitman
  • 2788
LDA on an NA Pump?
« Reply #36 on: March 03, 2008, 05:30:34 pm »
neat.....doesn't look to hard. I'll be doing that as soon as I get some time.
