Author Topic: Heat shield help  (Read 5546 times)
September 19, 2006, 05:17:52 am
91 ECO
Heat shield help
« on: September 19, 2006, 05:17:52 am »
I am in the process of replacing my injectors and I have one heat shield that will not come out.  I searched here yesterday and have tried to heat it up with a torch with no luck.  I have also worked on it with a pick several times.  I want to exhaust all other alternatives before trying the compression method.  Any ideas??  How much can I heat it up with a torch before it's a problem?
Thanks,
Mark
Reply #1September 19, 2006, 07:46:06 am
MacGyver
  • 245
Heat shield help
« Reply #1 on: September 19, 2006, 07:46:06 am »
Try threading a long lag/screw into the hole enough to get a good hold, hook a pair of visegrip pliers onto it, and tap the gripping end of the pliers with a hammer ie up and away from the engine.
Like a ghetto slide hammer effect.
Reply #2September 19, 2006, 08:19:23 am
91 ECO
Heat shield help
« Reply #2 on: September 19, 2006, 08:19:23 am »
Tried threading a bolt into the hole in the shield, but my vice grips keep slipping  :? .
Reply #3September 19, 2006, 10:10:45 am
MacGyver
  • 245
Heat shield help
« Reply #3 on: September 19, 2006, 10:10:45 am »
If you mean you can't get it to thread into the hole, use something with a coarse thread like a lag or screw as I recommended, not a bolt, and turn it in with the appropriate tool (socket, screwdriver).
If you mean your vise grips are slipping off the end of the screw when you hit it, well dunno what to tell you. Try a different grip right on the screw head, and use genuine Vise Grips, the generic ones are't worth a damn.
Reply #4September 20, 2006, 05:10:28 am
Doug
heat shields
« Reply #4 on: September 20, 2006, 05:10:28 am »
Good idea on the lag screw. Why not just crank the engine over? The compression should pop it out just fine.
Reply #5September 20, 2006, 08:49:51 am
91 ECO
Heat shield help
« Reply #5 on: September 20, 2006, 08:49:51 am »
Got it with a longer lag screw.  Thanks for your help.
Mark
Reply #6August 08, 2007, 08:26:04 am
jari_veedub
  • 20
Stubborn heat shield
« Reply #6 on: August 08, 2007, 08:26:04 am »
Great Forum...
I had the same problem.  Good technique.
 :D
85 jetta diesel  (297k miles)
92 jetta turbo diesel (235,k miles)
85 golf (gas) (163k miles)
93 golf turbo diesel (188k miles)
Reply #7August 11, 2007, 01:43:12 pm
Quantum TD
  • 1195
Heat shield help
« Reply #7 on: August 11, 2007, 01:43:12 pm »
Great minds must think alike. I had the same problem on mine and did the same thing: coarse thread screw and yank out. Works like a charm.
