Author Topic: scirocco brakes, definetly recommended  (Read 8753 times)
September 17, 2006, 06:57:57 pm
« on: September 17, 2006, 06:57:57 pm »
so i swapped scirocco front brakes on to my car, and holy hell, what a difference, i highly recommend it to anyone running around with an a1 car.  it takes as much time as installing new calipers, and it's a very nice upgrade.
Reply #1September 18, 2006, 02:30:17 pm
« Reply #1 on: September 18, 2006, 02:30:17 pm »
8v or 16v?
Reply #2September 18, 2006, 04:15:28 pm
« Reply #2 on: September 18, 2006, 04:15:28 pm »
oh 16v, i only did the fronts my rears are getting mk3 drums
Reply #3September 18, 2006, 04:22:27 pm
« Reply #3 on: September 18, 2006, 04:22:27 pm »
what size are mk3 rears? stock mk1 is 190mm (except caddy, 200mm) right?
Reply #4September 18, 2006, 05:07:24 pm
« Reply #4 on: September 18, 2006, 05:07:24 pm »
the mk3s are 200, i think the mk1s are 180, i'm not sure but they're small and even my 14" wheels make them look tiny, i think i may need a different proporting valve for this though, the front wheels are definetly doing most the braking, and lock up while the rears won't lock up for me,  i kinda wonder if the big drums will help with that though
oh yah and caddies are 200mm's yes sir
Reply #5September 18, 2006, 07:06:29 pm
Kudagra
  • 738
    • www.no-coast.com
« Reply #5 on: September 18, 2006, 07:06:29 pm »
I just picked up some 95 VR6 Passat spindles and brakes.
Ill try them out when I get the engine back together.
I have more crap then I need for one car...guess that means I need another car.
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
Reply #6September 18, 2006, 07:37:03 pm
« Reply #6 on: September 18, 2006, 07:37:03 pm »
That's why I have 5  :D
Reply #7September 18, 2006, 09:19:29 pm
moosiah
  • 106
brake swap
« Reply #7 on: September 18, 2006, 09:19:29 pm »
Did this yrs ago....    16v sirrocco frts w 200x 40 rears.....  works good. red box mintex pads...    squishy pedal tho. I think a 22 mm master would help :D
'81 Frankenbunny: part rabbit, sirroco, golf ,caddy cabrio ,jedda and ! ford teimpo! w a little more Audi and soon some Peogeot too!!!!
Reply #8September 19, 2006, 05:27:04 pm
« Reply #8 on: September 19, 2006, 05:27:04 pm »
i had a hard pedal, but it seems like i might be getting air in some where.
Reply #9September 20, 2006, 08:14:38 am
macsdub
  • 165
« Reply #9 on: September 20, 2006, 08:14:38 am »
swishy pedal??on that above post??i like the stock master,dont upgrade to that 22mm yet,i prefer the better modulation the smaller master provides
most of the time this is hilfolk'r... ive forgotten my password
Reply #10September 20, 2006, 10:12:04 pm
moosiah
  • 106
« Reply #10 on: September 20, 2006, 10:12:04 pm »
YO!!!!!! Macsdub    that's a 'sQuishy  pedal ....... :cry:  NOT a sWishy pedal........: :shock:     I may work in the entertainment bizz in SF , but I don't hang out there,  live 50 mls north,,,, up near where Tusker lives .......     in the heart of the whine country..... :lol:
Reply #11September 21, 2006, 05:59:03 pm
« Reply #11 on: September 21, 2006, 05:59:03 pm »
if i could find an early canadian passat with drums they had like 220mm drums on the ass end, but that's a needle in a hay stack
Reply #12October 15, 2006, 03:49:34 pm
VW Smokr
  • 114
« Reply #12 on: October 15, 2006, 03:49:34 pm »
Quoting Trev0rbr: "if i could find an early canadian passat with drums they had like 220mm drums on the ass end, but that's a needle in a hay stack"
Hadn't heard that before. AFAIK all the early Passats (Dashers) & Audi 80s(Foxes) came with the 200mm drums. Theoretically, some really early/really cheap Golf 1/Rabbits came with 230mm front drum brakes, but I've never seen any.
OTOH many, if not most, of the 78-84 Audi 5000 models came with 230mm rear drums (4 x 108mm wheel lugs), that should be able to be retrofitted to A1, A2, B1, B2, and BX chassis without a huge hassle. Some even had externally-finned drums for additional cooling! [Lessee.. with the fins, they'd look like about 10.5" wide drums, shining through the wheel openings, not exactly tiny any more.] Seems like most ran off 22mm master cylinders.
J.R.
