Author Topic: water pump pulleys?  (Read 2245 times)
September 17, 2006, 04:57:31 pm
greyrabbit
  • 11
water pump pulleys?
« on: September 17, 2006, 04:57:31 pm »
So I'm putting my engine back together and I'm about to put the v-belt pulley back on the new water pump and drat...the new pump has a different pulley hub than the old one.  I'd rather not take everything apart and get another pump, can I simply get the right style v-belt pulley or will it not line up.
Any help appreciated.
Reply #1September 18, 2006, 01:51:26 pm
water pump pulleys?
« Reply #1 on: September 18, 2006, 01:51:26 pm »
I know mk1s are either 30mm or 40mm hubs. I did swap a 40 to 30 once and I had to use washers behind the pulley to align it properly. It's still not 100% perfect but it works just fine (so far)
