Author Topic: Bringing the 1.6TD Idle Down?  (Read 3318 times)
September 16, 2006, 01:26:21 pm
Op-Ivy
  • 513
« on: September 16, 2006, 01:26:21 pm »
I did the "smog" mod and increased my fuel a bit. My idle is now higher(I know this is normal)
What screw do I turn to bring it down? I can't figure it out :P
Thanks, Matt
Reply #1September 17, 2006, 12:12:11 pm
Op-Ivy
  • 513
« Reply #1 on: September 17, 2006, 12:12:11 pm »
Anyone?
Reply #2September 17, 2006, 03:30:22 pm
andy2
« Reply #2 on: September 17, 2006, 03:30:22 pm »
Smogs thread for the 1.9 is the same as the 1.6.The #7 screw is what you will use to lower your idle.Be careful as this adjustment screw is usually seized up.Spray it with penetrating oil and work it back and forth very carefully as part of it is plastic.I believe that turning clockwise lowers the idle.
http://vwdiesel.net/phpBB/viewtopic.php?t=579&start=0
Reply #3September 17, 2006, 10:49:50 pm
BellCityDubber
  • 251
« Reply #3 on: September 17, 2006, 10:49:50 pm »
Quote from: "andy2"
When I did my adjustments, #7 didnt do anything for my idle, but I moved #6, and it seemed to do the trick
Reply #4September 18, 2006, 09:17:24 am
andy2
« Reply #4 on: September 18, 2006, 09:17:24 am »
If the #7 screw doesn't seem to back down the idle it may be that its sitting on the #8 screw's stop.In which case the #8 screw would need to be backed out to lower the idle.The #6 screw shouldn't need to be touched unless your really screwing around hardcore with the pump :twisted:.
Edit:My mistake turning #7 counterclockwise lowers idle.
Reply #5September 18, 2006, 03:43:03 pm
Op-Ivy
  • 513
« Reply #5 on: September 18, 2006, 03:43:03 pm »
Thanks for the input guys! Lowered it a bit and sounds about right now! I don't have a tach (clock) so I can't tell for sure what its at.
Reply #6September 18, 2006, 04:05:41 pm
zagarus
  • 619
« Reply #6 on: September 18, 2006, 04:05:41 pm »
well we should get you a tach shouldn't we.  easy hook up, i think  :P
Reply #7September 19, 2006, 07:07:39 am
Op-Ivy
  • 513
« Reply #7 on: September 19, 2006, 07:07:39 am »
Haha I'm with you on that one!
