Pre-Chambers . . . Where To Buy ? ? ?
Topic: Pre-Chambers . . . Where To Buy ? ? ? (Read 4810 times)
September 30, 2004, 09:42:08 pm
1985JettaTD
September 30, 2004, 09:42:08 pm »
Anyone know where i can buy just the pre-chambers for a 1.6L Turbo Diesel? I am in Vancouver BC. I have tryed the local dealers and my local import shop (Bow-wow) and have not be able to find them. Thanks for all the help!!!!
October 01, 2004, 11:38:32 am
1985JettaTD
October 01, 2004, 11:38:32 am »
Anyone . . . . . . ? ? ? ? ? I really need them. My mechine shop said that my head shoudnt be put back on with the pre-chambers in as bad shape as they are (the head has over 500 000Km City on it) The mechine shop is looking and i thought i would do my share and see if i could find them but it is not looking very good. Any info that any of you have would be awsome!!!! Thanks again!!!!
October 01, 2004, 01:02:59 pm
RedRotors
October 01, 2004, 01:02:59 pm »
You probably talk about the circular piece of steel with an hole in it , stamped in the head.. because the pre-chamber itself is casted in the head and cannot be replaced..
Any good shop that rebuilt diesel engine should have them in stock or at least order them..
Marc/
PS: look with Piers Diesel in BC, he can probably give you an hand..
2k1 Golf TDI, 11mm pump, HFLOX Warp 5, VNT17, Wavetrac, 4" Lift
91' VW Golf Country
94' Dodge RAM 2500, 4x4, Cummins, 5 spds, 191's, 215hp injectors, SB Clutch
03' Dodge RAM 2500, 4x4, Cummins, 6 spds, MBPR 4 ", custom intake, Smarty Jr
www.mikrotuning.com
www.hflox.com
October 01, 2004, 07:54:19 pm
Dr. Diesel
Authorized Vendor
October 01, 2004, 07:54:19 pm »
call cesar at 905-826-8706
tell him bryson sent you.
October 01, 2004, 08:03:24 pm
QuickTD
October 01, 2004, 08:03:24 pm »
Altrom
http://www.altrom.com
has prechamber inserts available for the 1.9TD, but none are listed for the 1.6, might be worth a call. I'm not sure if the inserts from the 1.9 will fit the 1.6.
October 03, 2004, 10:15:57 pm
1985JettaTD
October 03, 2004, 10:15:57 pm »
Dr. Diesel: this guy does he have them for sure? i have found some at at the volkswagen dealer after digging around a but more but they want 70 bucks each. do you know what this guy charges for them? thanks for all the help!!!
October 06, 2004, 06:36:12 pm
janb
October 06, 2004, 06:36:12 pm »
sorry for the delay, on a road trip (5500 miles)
try here
http://www.aluminumheads.com/
For More Information Call: 503-230-0852
OUTSIDE PORTLAND: 1-800-978-HEAD or 4323
4701 SE 24th
Portland, OR 97202
ask for Wayne or Chuck, you are needing "Pre-chamber-inserts"
The Stealth Rabbit
VW-d's are forever
