Author Topic: GM 6.2l injector pump mods  (Read 11898 times)
September 02, 2006, 09:19:30 pm
deezul ryan
  • 24
    • http://www.dieseldude.com
« on: September 02, 2006, 09:19:30 pm »
I have an 87 blazer to fix and it needs the injector pump rebuilt.  Since it will be off and apart is there any thing i can do to it to squeek a few more ponys?
94 jeep YJ 2.4 TD (vw diesel powered)
81 vw pickup 2.0 16v dual carbs NOS soon to be TDI-M powered
80 vw pickup 1.5 TD
53 Studebaker M35 7.8 TD (23,030 GVWR)
Reply #1September 03, 2006, 09:06:54 am
Kudagra
  • 738
    • www.no-coast.com
« Reply #1 on: September 03, 2006, 09:06:54 am »
Really I have no idea. But I would like to know about your YJ. What transmission are you using?? I would love to do this to my 91 XJ.
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
Reply #2September 03, 2006, 09:48:13 am
SMOKEYDUB
  • 630
« Reply #2 on: September 03, 2006, 09:48:13 am »
i would try and see if i could bolt on a turbo setup i think i have seen a couple go for cheap on ebay. I also was thinking of doin a 1.6 or a 1.9 vw td in a yj. but i said screw it :D
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #3September 03, 2006, 10:22:33 am
QuickTD
  • 1156
« Reply #3 on: September 03, 2006, 10:22:33 am »
The stanadyne DB2 pump is easy to adjust for increased quantity. It's even less hassle than the VE pump because max quantity adjustments have no effect on idle speed. This article refers to the ford 6.9/7.3 but the GM pump is the same.
http://www.members.shaw.ca/k2pilot/Injection%20pump%20adjustment%20article.htm
 Only difference is that you are more likely to bust the block or crank on the GM... :D
Reply #4September 03, 2006, 11:23:06 am
SMOKEYDUB
  • 630
« Reply #4 on: September 03, 2006, 11:23:06 am »
ya those gms are real winners :D  6.2 and 6.5 are the same with the crank thing.6.5s arent as bad but those 6.2 s.......
(courtesy of GILES)
Reply #5September 03, 2006, 08:36:23 pm
andy2
« Reply #5 on: September 03, 2006, 08:36:23 pm »
http://dieselplace.com/forum/index.php
This site has lots of info on the 6.2,6.5 duramax etc..
Reply #6September 04, 2006, 08:08:38 am
deezul ryan
  • 24
« Reply #6 on: September 04, 2006, 08:08:38 am »
my jeep has the stock AX5 5speed the truck was a 4cyl.
im not a fan of the gm diesels but its what i have to work on.  they sound like they are gonna blow up at idle when new!
i have to update my website but there is a picture of my jeep on it
www.Dieseldude.com
80 vw pickup 1.5 TD
Reply #7September 04, 2006, 08:37:09 pm
moosiah
  • 106
6.2
« Reply #7 on: September 04, 2006, 08:37:09 pm »
Hi the 6.2 chev is not as bad as I used to think ..........  If you can get the one w the serpentine belt get up .....  the J model is the one you want.......  they aren't  the horse power kings.....  but their the lightest V8 , they have the highest rev limit (3600) and are cheep...  bolt on a turbo...    :)
'81 Frankenbunny: part rabbit, sirroco, golf ,caddy cabrio ,jedda and ! ford teimpo! w a little more Audi and soon some Peogeot too!!!!
Reply #8January 18, 2007, 07:22:44 am
AdAm84
« Reply #8 on: January 18, 2007, 07:22:44 am »
banks makes a turbo kit for the 6.2 that gives it more *** than a stock 6.5. and its all mechanical  :) 6.5's are good, but they have too many electronic issues.
why would you put a vw diesel in a yj? I'm not criticizing, i'm just curious. I would swap out the four banger for a 4.0 before anything else. It's just that the vw diesels are so small displacement. why not a cummins 4 or a smaller 6 cylinder of some sort? again just curious.
Reply #9January 18, 2007, 09:23:04 pm
deezul ryan
  • 24
« Reply #9 on: January 18, 2007, 09:23:04 pm »
i think i am gonna make a home brew banks wanna be.
the gas 4cyl had to go.  it almost does 55mph with 33's in 4th gear.  i had to change the engine.  i decided on the vw because i knew how to work on it and at the time i couldnt afford a 4cyl cummins.  diesels are cool and i wasnt going to put in a gas motor in it and i like to be different.
york?
80 vw pickup 1.5 TD
Reply #10January 19, 2007, 04:58:54 pm
AdAm84
« Reply #10 on: January 19, 2007, 04:58:54 pm »
yep. home of the jeep show. btw if you were there you may have seen the guy with what i belive to be an izuzu turbo diesel six in it. that was the best sounding diesel there.  :twisted:  None of the engine swaps are all that simple, and the 4.0 is easier to swap as long as your only bolting power mods on. trust me, don't build one up. there will be more problems than you can imagine. so did you put the VW motor in? I'm curious how that went.
Reply #11January 19, 2007, 05:43:30 pm
deezul ryan
  • 24
« Reply #11 on: January 19, 2007, 05:43:30 pm »
email me.  ill send you what i have.
[email protected]
there is a bad picture of it at www.Dieseldude.com
80 vw pickup 1.5 TD
Reply #12February 05, 2007, 03:17:24 pm
« Reply #12 on: February 05, 2007, 03:17:24 pm »
volvo powered jeep, thats cool
