Author Topic: MPH/RPM  (Read 7252 times)
September 27, 2004, 03:53:14 pm
aidan
MPH/RPM
« on: September 27, 2004, 03:53:14 pm »
Just bought a '91 Jetta 1.6 TD today, without rev counter. I was wondering if anyone knew what the mph/rpm is in each gear, it is a 5 speed?
Forgive me if this is a repeated question, I couldn't find anything with a search.
Reply #1September 27, 2004, 04:36:45 pm
VWRacer
  • 649
MPH/RPM
« Reply #1 on: September 27, 2004, 04:36:45 pm »
Aidan, go take a look at the bottom of the bellhousing on your car's trans -- you are looking for a code like "AWY" or "AGS". Then go to this website and plug in the numbers. You can build a complete gear chart from the info on that page.
Cheers! Stan
PS - There are more VW transmissions listed here. If your gearbox is one of these, just plug the numbers into the java calculator on the website I linked to above to build your gear chart.
Stan
C-Sports Racer
Reply #2September 27, 2004, 07:03:15 pm
Wingaman
  • 7363
    • http://www.dmfdiesel.com
MPH/RPM
« Reply #2 on: September 27, 2004, 07:03:15 pm »
The redline of the VW diesel is 4500rpm if you don't know it. Good to know to build a chart  :)
371-B, Ch. Ste-Marie
Ste-Marthe QC J0P 1W0
Reply #3September 28, 2004, 09:42:47 am
chrissev
  • 694
Re: MPH/RPM
« Reply #3 on: September 28, 2004, 09:42:47 am »
Quote from: "aidan"
It will be an AWY tranny.  Top gear is .89, so at 100km/hr you will be doing around 3100rpm.
Reply #4September 28, 2004, 10:32:20 am
Blades
MPH/RPM
« Reply #4 on: September 28, 2004, 10:32:20 am »
TD don't have the AWY transmission.
They normally have 3.94 + 0.75 5th, so 100km/h = 2750rpm
Reply #5September 30, 2004, 06:04:23 pm
andy2
MPH/RPM
« Reply #5 on: September 30, 2004, 06:04:23 pm »
my 91 jetta TD has a 86 TD trans in it and at 100 km/hr its at about 2625 rpm
Reply #6October 01, 2004, 07:50:36 pm
chrissev
  • 694
MPH/RPM
« Reply #6 on: October 01, 2004, 07:50:36 pm »
Quote from: "Blades"
2750 in fourth maybe.  You can do 120 with the .75 and be spinning 3000 or so.
Reply #7October 03, 2004, 01:11:55 am
dieselpower
  • 177
MPH/RPM
« Reply #7 on: October 03, 2004, 01:11:55 am »
i couldn't tell you what kinda tranny's in my car cuz it's been rplaced too many time to sount but here are ym numbers......i used the volkwagen dealerships vag com thinng to do this so im pretty sure its accurate.
2nd gear
rpm         km/h
2500        33
3000         42
3500        50
4000         56
4500         65
5000        70
3rd gear
3000         65
3500          73
4000         84
4500          93
5000         108
4th
3000         90
3500         103
4000         118
4500          130
5000         145
i dont have a working tach yet so i use my speed as shift points. sorry i didnt do 1st or 5th but i spin through 1st and i don't hit 5th when i race so i didnt bother checking them out. i'll check out my tranny tommorow but i have a 1.6L TD in it.
anyway heres what i know
mark
84 rabbit 1.6TD
because real cars don't have sparkplugs
Reply #8October 03, 2004, 06:45:55 pm
Hammy
  • 169
mph/rpm?
« Reply #8 on: October 03, 2004, 06:45:55 pm »
Has anyone found any ring gears, and such, to make these things longer legged. My ACH revs just over 3000 at 100 kph, and like 3600 at 120 kph. I'd like to find something more like TDI ratios. Any ideas?
Hammy (Jason)
'96 Golf, 1.8 gas
'91 Golf, 1.6 TD
'98 GMC 1500 4x4, 5.7L (doing my best to save the oil companies, 85 liters takes me 600 km)
'78 Ford 3000 3cyl, 201 diesel, with loader
Reply #9October 08, 2004, 08:23:11 pm
chrissev
  • 694
Re: mph/rpm?
« Reply #9 on: October 08, 2004, 08:23:11 pm »
Quote from: "Moonstone"
You must have an '85 1.6 diesel.  The ACH had the .89 fifth.  Crappy, crappy crappy.  Why does VW do this to their cars?  Especially when they were putting GPs and GYs (.71 fourth) in their 1.6 non turbo diesels in the early 80s.  I have no idea what you can do about this lousy fifth gear situation.  Maybe you want to try to find a good AGS to put in your car to solve the problem.  Now if VW would only make a 5spd for their golfs and jettas with the wonderful .68 fifth gear that was in the deluxe brazillian fox.  THAT car would move on the highway!
Reply #10October 17, 2004, 02:45:07 pm
Hammy
  • 169
MPH/RPM
« Reply #10 on: October 17, 2004, 02:45:07 pm »
chrissev;
 You are correct about that tranny, it came from an 85, 1.6n/a Golf. Very good assumption!   I think that I am going to find another tranny, I just wish I could find one similar to our '99 TDI. It would be great on the highway.
Hammy (Jason)
'96 Golf, 1.8 gas
'91 Golf, 1.6 TD
Reply #11October 18, 2004, 08:09:58 am
ThumperTheRabbit
  • 5
    • http://www.Subaru-svx.net
MPH/RPM
« Reply #11 on: October 18, 2004, 08:09:58 am »
I have a 1981 Volkswagen Rabbit diesel (4-speed) and have always wondered what kind of RPM's that little engine is pulling as I drive down the highway... Anyone know about that tranny??? I was also thinking about doing a 5 speed swap into it... But I'd like to know if I'll be turning lower RPMs with the 5 speed than the 4 speed... Anyone think they can help???
Thanks!! :)
1981 VW Rabbit L Diesel -- 133k miles... 47mpg :):D
Reply #12October 19, 2004, 11:33:34 am
janb
  • 167
MPH/RPM
« Reply #12 on: October 19, 2004, 11:33:34 am »
chrissev;
I like the ACN / ASF 'gas' ratios.  They are adequately tall for cruising, but I take a 10% mileage hit (seems the VW-D's like to be 'run-hard')
The AGS seems to be best of Diesel choices
I find best economy in a 4 speed, and they are available in 'tall' (e-on knob-4th- GC) or low (GP)  I get best mileage with the low ratio, but the tall ratio can preserve hearing loss  :wink:
The Stealth Rabbit
VW-d's are forever
