Author Topic: common problem for oil pressure loss? 1.9 idi  (Read 4560 times)
August 25, 2006, 03:27:30 pm
SMOKEYDUB
  • 630
« on: August 25, 2006, 03:27:30 pm »
i am aquiring a 95 passat idi and it has 0 oil pressure at the cylinder head but doesnt make any noise. Oil light is on all of the time but runns very smooth and quiet.other than that its pretty good except the crank is starting to wobble. engine was rebuilt 5 years ago it was maintained and not abused. rebuilt by vw reman so im asuming the used good stuff.
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #1August 25, 2006, 04:02:10 pm
QuickTD
  • 1156
« Reply #1 on: August 25, 2006, 04:02:10 pm »
Intermediate shaft bearings and/or the seal on the oil/vacuum pump drive shaft are common causes of low oil pressure.
Reply #2August 25, 2006, 04:03:16 pm
SMOKEYDUB
  • 630
« Reply #2 on: August 25, 2006, 04:03:16 pm »
thanks dude im also thinkin about the oil pump pressure relief valver maybe stuck open.
(courtesy of GILES)
