General Information
General
Do I need this?
Topic: Do I need this? (Read 5106 times)
August 18, 2006, 12:43:58 pm
VelocityConservation
Do I need this?
August 18, 2006, 12:43:58 pm »
I have a '90 NA Jetta and the good chassis. I have a TD motor from a '92 Jetta (Canadian car). The sensor (heater) that the red arrow is pointing to. What is it? what does it do? My NA chassis does not have the electrical connection for this. Do I need it? Can I bypass?
http://i96.photobucket.com/albums/l193/PhlatOut_2006/TD-IntakeHoses-03.jpg
Here is a closeup of the sensor itself (after cleaning)
Thanks, In advance.
90 TD Jetta, NA to TD swap completed '07
August 18, 2006, 01:34:00 pm
DVST8R
Do I need this?
August 18, 2006, 01:34:00 pm »
No.
The Brett of the board...
The Dark Side of Beauty.
[/i]
August 18, 2006, 02:51:48 pm
anarchyx34
Do I need this?
August 18, 2006, 02:51:48 pm »
Yeah my TD has that too. What is it for?
August 25, 2006, 06:24:58 pm
VolkSport
Newbie
Do I need this?
August 25, 2006, 06:24:58 pm »
It's a heater that heats up the air coming from the PCV into the intake to prevent ice crystals going through the turbo. That's what I've heard anyways....
'60 Beetle
'85 Jetta TD
Dune Buggy
August 25, 2006, 11:00:32 pm
hillfolk'r
Do I need this?
August 25, 2006, 11:00:32 pm »
ice crystals arent gonna hurt you too much,i water inject into my turbo air inlet,,but a plugged up pcv hose due to ice isnt a good thing it could happen in real cold weather,the length of the hose can cause condensation to freeze in the cold weather
Throttle cables ftw
August 26, 2006, 09:36:52 am
Heater for PCV Hose
August 26, 2006, 09:36:52 am »
Thanks everyone for the answer. I am going to follow Andrews suggestion and wire it inline with the stop solenoid.
August 26, 2006, 09:51:57 am
DVST8R
Do I need this?
August 26, 2006, 09:51:57 am »
I will expand on my answer today, as I have a little more time. I never like to put half burnt junk back through my engine, as such I have a catch can for the breather, and no heater, the hole has been plugged (with a welded precup-- thank's to PP) Normally I run a smooth radius CAI, but as I am switching turbo's and turbo locations this winter in the build, I thought I wouldn't bother until that point.
[/i]
August 27, 2006, 08:37:39 pm
PCV Catch Can
August 27, 2006, 08:37:39 pm »
Dvst8tr, could you post some pics and elaborate on your catch can setup?
Thanks,
General Information
General
Do I need this?
