Author Topic: WTB: AAZ 1Y Stuff Injector hard lines and Full Timing Cover 3pc set IM pulley  (Read 8205 times)
May 13, 2026, 10:26:06 am
vwpieces
  • 51
Pretty much found everything on the list.
Thanks RabbitJockey.
« Last Edit: May 30, 2026, 09:20:18 pm by vwpieces »
Reply #1May 14, 2026, 10:09:05 pm
  • 2932
Re: WTB: AAZ Stuff Injector hard lines and Full Timing Cover 3pc set
« Reply #1 on: May 14, 2026, 10:09:05 pm »
 My buddy had a rod go through the block on his AAZ.
I'm going to see how many parts will swap over to a 1.6.
He said I could sell the leftover parts to you.
Craig
Reply #2May 21, 2026, 06:41:45 pm
vwpieces
  • 51
« Reply #2 on: May 21, 2026, 06:41:45 pm »
 Ad an IM shaft Pulley to the want list. 028115021B I think is the part number. Should fit all 1.9 into the TDI 1Z, alh.
It is smaller than the 068 on the 1.6L
And a set of very good used or New pistons for a 1Y engine. Not the same as AAZ. New can be had but trying here first
« Last Edit: May 21, 2026, 06:45:20 pm by vwpieces »
Reply #3May 22, 2026, 12:37:20 am
  • 2932
 I think the pully looked good on the 1.9 I'm taking apart. I'll check.
Reply #4May 22, 2026, 09:21:43 am
vwpieces
  • 51
Reply #5May 30, 2026, 09:22:19 pm
vwpieces
  • 51
I Think I am OK with everything for now. Lotta SHTuff picked up from Rabbit Jockey and new pistons should be here in a couple days.
Reply #6May 30, 2026, 10:15:51 pm
  • 2932
Good. I think you can broaden your search to include AHU parts.
 Which are often easier to find.
