Author Topic: Internally Balanced Crankshaft?  (Read 11984 times)
April 30, 2026, 04:53:52 am
1.6Lmarine
  • 28
« on: April 30, 2026, 04:53:52 am »
Good Morning,
Just a quick question today.
Is the crankshaft on a 1.6L TDI ME from a 1987 Jetta internally balanced?
Thanks so much!
Craig
Reply #1May 14, 2026, 10:02:39 pm
  • 2930
Re: Internally Balanced Crankshaft?
« Reply #1 on: May 14, 2026, 10:02:39 pm »
I am not sure what that means.
 It is balanced.
Reply #2May 15, 2026, 01:38:43 am
VWSmokr
  • 39
« Reply #2 on: May 15, 2026, 01:38:43 am »
In 1987, VW Jetta was not offered with any TDI engines, only IDI. However, it seems that you may be asking if, for a Jetta TD engine, an EXTERNAL (weighted & indicated as to position) damper or flywheel is needed to achieve a balanced reciprocating assembly (as is common on many Detroit-built domestics). AFAIK... No. They are all supposed to have the INTERNAL components balanced together. OTOH a $erious performance assembly, especially one intended for high rpm service, could include any damper/pulley, as well as the flywheel & clutch assembly in the balancing process.
J.R.
SoCal
