Author Topic: info ECU  (Read 22523 times)
June 08, 2025, 12:53:46 am
sabatino
  • 40
info ECU
« on: June 08, 2025, 12:53:46 am »
hi. did you do a complete tdi swap on a golf mk1 with all the electrical system and ecu? where did you position the ecu? can you post photos?
does the rev counter signal come out of the ecu's electrical system? could you tell me what colors they are? I'll post photos of my swap.
Thanks in advance to everyone.
Reply #1June 08, 2025, 01:28:42 am
sabatino
  • 40
Re: info ECU
« Reply #1 on: June 08, 2025, 01:28:42 am »
I'm sorry, how do you upload photos?
Reply #2June 08, 2025, 08:42:57 pm
  • 4549
Re: info ECU
« Reply #2 on: June 08, 2025, 08:42:57 pm »
Use a third party site like Imugur and just use the link for a blog, that will work.
Reply #3June 19, 2025, 01:57:04 am
sabatino
  • 40
Re: info ECU
« Reply #3 on: June 19, 2025, 01:57:04 am »
Reply #4July 01, 2025, 10:36:57 pm
  • 2920
Re: info ECU
« Reply #4 on: July 01, 2025, 10:36:57 pm »
 Good question.
There are a couple kinds of TDIs that usually get swapped into Rabbits.
 The AHU/1Z is much like the Rabbit 1.6 engine. External waterpump and all.
 Looks like that's what you are using.
 The ECU has an immobilizer, but it is just a relay, much like the seat belt interlock relay it can be easily bypassed.
With this setup you can use your rabbit instrument cluster.
 I think people have been putting the ECU in the raintray, under a cover and just running the (I think it was) black and yellow wire inside to the power when ignition on fuses.
 Along with the accelerator peddle wires.
 For the speedometer, there is a special cable you can buy that will connect the 02J trany to the cluster.
 But it looks like you are using the 020 trany and the stock cluster works with the same speedo cable.
Tornado red, '91 Golf 4 door,
