Author Topic: So what might cause this to happen?  (Read 9999 times)
April 19, 2025, 07:22:45 pm
« on: April 19, 2025, 07:22:45 pm »
Yesterday, I was pulling the bumper off the front end along with the grill and lights.  I am getting ready to paint the bugger after owning it since 2017.  OK, a little long with the upgrade, but hey, I was busy.
So I looked at the alternator as I was working away and thought;  The voltage sure has been bouncing around a lot on the gauge lately. I wonder if the belt is loose again.
Well, not so much, but the pulley was about 1/4 inch away from the fin plate.  WTH???
How does something like that happen?  I have not touched that part in a long time.  When I got it off so I could tighten the nut, I noticed that the key way that is supposed to be in there to lock it all up was gone as well.
So has anyone had that happen to them?  I surely have not seen such in any vehicle I have ever owned.
Let me know your story.
No not the one about your crazy sister or brother-in-law.  I can read those on FarceBook.
Reply #1April 27, 2025, 10:34:51 pm
  • 2931
Re: So what might cause this to happen?
« Reply #1 on: April 27, 2025, 10:34:51 pm »
Does it have a tapered shaft?
 I think I remember putting a pully on with an impact and a prayer after seeing there was no place for a key.
 I think it's, at least some Mk2 alternators are like the cam and there is no key.
Reply #2May 01, 2025, 08:34:17 pm
« Reply #2 on: May 01, 2025, 08:34:17 pm »
The shaft is straight, not tapered like on the IP or Cam.  More like a lawnmower setup.
Reply #3May 01, 2025, 10:41:06 pm
  • 2931
« Reply #3 on: May 01, 2025, 10:41:06 pm »
So did the pully tear up the shaft from spinning on it?
Reply #4May 02, 2025, 09:07:07 pm
« Reply #4 on: May 02, 2025, 09:07:07 pm »
I caught it in time to prevent any of that.  There just wasn't a keyway in the slot, and the pulley was still sort of tight with the lock washer.  Getting it apart was a pain, as the keyway is supposed to allow you to take the pulley off and not have the shaft spin.  A screwdriver, keenly placed while wrenching, did the trick.
« Last Edit: May 02, 2025, 09:11:34 pm by ORCoaster »
