Author Topic: M-TDi Timing  (Read 8301 times)
December 15, 2024, 07:54:33 am
VWT4MTDI
  • 1
M-TDi Timing
« on: December 15, 2024, 07:54:33 am »
Hey group!
I'm in the process of building up an AHU with a Land Rover 300 pump and I need some help with getting it all timed up correctly.
I've read so many things on the forums that I'm pretty confused!
I've rebuilt the head, so I am also replacing the cambelt at the same time, so the belt is not yet tight.
So far, I have set the crank and camshaft to TDC, camshaft sprocket is loose, IP pulley is loose.
I have the pump pinned in the timing slot.
What's next?
Do I need to tension the belt, tighten the camshaft pulley and then adjust the pump?
Thanks!
Reply #1December 15, 2024, 11:24:57 pm
  • 2920
Re: M-TDi Timing
« Reply #1 on: December 15, 2024, 11:24:57 pm »
I'd tension the belt first.
 Otherwise if the cam is tight, when you tension the belt it could move some.
Spin it around by hand a couple times then check cam/crank timing.
And then the injection pump timing should be set right.
Tornado red, '91 Golf 4 door,
