Author Topic: AAZ rod wear @tangs  (Read 3803 times)
June 05, 2023, 06:01:39 pm
oblique
  • 317
    Diesel while you can.
AAZ rod wear @tangs
« on: June 05, 2023, 06:01:39 pm »
Is this normal? All the rods have some level of these marks and I can feel them. Pics of the bearings too, i mixes up the caps and rods but im assuming the ones with the visible 'trough' in the middle are the rod ones, pictured below.
Humbly rolling coal.
90 1.6TD Jetta
79 1.6Na Rabbit
Reply #1June 05, 2023, 07:40:29 pm
  • 2932
Re: AAZ rod wear @tangs
« Reply #1 on: June 05, 2023, 07:40:29 pm »
 No I don't think that's normal.
It probably won't hurt anything.
 Does the other side of the bearing look different? Is it causing the bearing to wear different?
Reply #2June 06, 2023, 05:59:05 pm
oblique
  • 317
« Reply #2 on: June 06, 2023, 05:59:05 pm »
My mistake, the following must've been on the rod side, they match the patterns on the rod shells but in color only...there is no perceptible wear on them:
« Last Edit: June 08, 2023, 06:58:12 pm by ORCoaster »
90 1.6TD Jetta
79 1.6Na Rabbit
