Author Topic: Compression test on cold engine?  (Read 4141 times)
August 14, 2006, 10:50:15 pm
Erase_The_Eraser
  • 13
« on: August 14, 2006, 10:50:15 pm »
Hey there! I hate that my first post is going to be a troubleshooting issue on here, however I guess thats just how it goes sometimes....so, the dilemma. I read about these amazing little 1.6 diesels and fell in love...after doing some searching a friend told me about one that was sitting out at a dealership. I ended up purchasing a 1992 Jetta turbo-diesel (eco-diesel model) for a total of about 600 dollars. High miles but the test drive told me otherwise, seemed solid...minus the few things it needed. Since then I have replaced parts and am now just waiting on several bolts before I start driving her. Along the way I decided to run a compression test and then it all came to a somewhat discouraging halt when my numbers came back, 350-150-180-200.
Yikes! So, the question I'm asking is - Will compression numbers be significantly higher with a warm engine? since the vehicle can not be run right now I can not find out until the end of the week when the rest of my parts come in.
Thanks!
Reply #1August 15, 2006, 04:08:01 am
Doug
Compression
« Reply #1 on: August 15, 2006, 04:08:01 am »
Yes, it will trend higher. If it starts and runs without difficulty then run it for a few weeks before testing again. There may just be some foreign matter on the valve seats or some stuck rings. If there is still the difference then maybe a valve job and or rings is in order.
Reply #2August 15, 2006, 07:53:00 am
« Reply #2 on: August 15, 2006, 07:53:00 am »
Hmmm... I remember seeing some compression numbers on a toyota diesel 2.4D engine.
Compression went like this: 320-190-140-90
(not exact numbers, but close enough)
The engine wanted to run, but blew out some serious black smoke.. that one cylinder was trying to run the whole motor  :lol:  what a beast!
Basically what probably happened was the driver let the EGT's go too high, and burned out the last 3 cylinders, since thats the orientation of the exhaust manifold.
I'm wondering if your car has the same problem.  The most problematic cylinders of heat failure would be the 2 middle ones by the way that the exhaust manifold is ducted.  As Doug stated though, it is quite possibly a valve/ring problem, maybe caused by overheating.
