Author Topic: what size torx bit to remove wheel cylinders?  (Read 5604 times)
August 14, 2006, 05:00:42 pm
Master ACiD
  • 328
« on: August 14, 2006, 05:00:42 pm »
im doing a brake overhaul and need a torx bit to remove the cheel cylinders. the auto parts store has no listing for vw, and they say they dont carry metrix torx bits?
Reply #1August 14, 2006, 05:57:15 pm
MacGyver
  • 245
« Reply #1 on: August 14, 2006, 05:57:15 pm »
Sorry don't know offhand what size it is you need, but torx is torx, no metric or imperial required. T-10, T-15, T-45, up to at least T-60.
Do yourself a favour though if you buy a set, and get Torx Plus, they fit & drive far nicer as I just found out. Brake job on father in law's 98 Lumina. Seized T-55's hold the caliper carriers on :roll:
Reply #2August 14, 2006, 06:34:08 pm
firestorm13666
  • 204
« Reply #2 on: August 14, 2006, 06:34:08 pm »
On my 86 golf they were allen heads not torxs.I think they were like 5,6,or7mm.
Reply #3August 14, 2006, 09:44:46 pm
Master ACiD
  • 328
« Reply #3 on: August 14, 2006, 09:44:46 pm »
i didnt know that torx was a universal sized tool. i guess ill grab a full set of torx plus.
and be sure to get 5 6 and 7mm sizes.
Reply #4August 14, 2006, 10:21:48 pm
  • 2932
wheel cylinders
« Reply #4 on: August 14, 2006, 10:21:48 pm »
I'm not sure what you are driving. Good time to suggest people put their vehicle type in their signature.
 I'm guessing they are allen head, not torx.
Reply #5August 15, 2006, 10:03:27 am
Master ACiD
  • 328
« Reply #5 on: August 15, 2006, 10:03:27 am »
its torx. ive cleaned the bolt heads up real well so i can see it better. its definitly torx.
Reply #6August 16, 2006, 12:58:26 am
  • 2932
wheel cylinders
« Reply #6 on: August 16, 2006, 12:58:26 am »
What kind of car is it?
 I haven't worked on anything newer than '91, that has wheel cylinders.
Reply #7August 16, 2006, 09:53:27 am
Master ACiD
  • 328
« Reply #7 on: August 16, 2006, 09:53:27 am »
its an 84 rabbit 4 door that originally had a gasonline engine and automatic trans. its been switched over to a diesel and manual trans though.
