Author Topic: AC system Questions  (Read 11078 times)
May 23, 2022, 11:21:27 am
93Ford
  • 63
AC system Questions
« on: May 23, 2022, 11:21:27 am »
Ok after doing some research i believe someone tried to put a mk1 ac system into my mk2. The mk2 has the evap lines coming out of the firewall and into the expansion valve but my car has none of that instead the ac lines go into the firewall and i guess connect to the evap. Should i even try to use this cobled together system or should i try and get the factory parts and redo the whole thing. I have no idea if the system has an expansion valve or orfice tube in it somewhere. One of the lines from the firewall goes to the drivers side of the car into the dryer which has the r134 high pressure port. Then also on the drivers side it goes from the dryer to the condensor then to the compressor. Theres another big line that goes from the compressor to the evap i think this is the line thats supposed to have the low pressure port on it but doesnt.
Reply #1May 23, 2022, 11:32:31 am
93Ford
  • 63
Re: AC system Questions
« Reply #1 on: May 23, 2022, 11:32:31 am »
On the oem system there are 2 switches the the hose going from the compressor to the condensor i imagine one is the cycle switch but what is the other switch and what are the part numbers.
Reply #2May 23, 2022, 06:45:21 pm
93Ford
  • 63
« Reply #2 on: May 23, 2022, 06:45:21 pm »
Is there parts from a newer vehicle thatll work or can be easily made to work for these old cars. It seems parts for the ac system are getting hard to find or they dont make at all anymore like the ac hoses was hoping to find some newer readily available parts thatll work with it.
Reply #3May 26, 2022, 11:22:25 am
93Ford
  • 63
« Reply #3 on: May 26, 2022, 11:22:25 am »
I guess not to many people deal with the ac systems in these cars. From what i can tell the ac lines go into the cab and if the guy did use a mk1 evap then the expansion valve should be in there right. It seems those switches i was looking at are really just safety switches i could just use the vintage air dryer with the single safety switch on it and thatll solve that problem. I finally managed to find someone local that can install a low pressure port after that i thing that should be all i need to get it working.
Reply #4May 26, 2022, 11:24:38 am
93Ford
  • 63
« Reply #4 on: May 26, 2022, 11:24:38 am »
How much of a job is it to get to the evaporator in the dash i would like to confirm weather or not theres the expansion valve in there. Is there any good videos or writups with pictures that show the process of getting in there
Reply #5May 26, 2022, 09:25:48 pm
  • 2932
« Reply #5 on: May 26, 2022, 09:25:48 pm »
From what I've heard, and I haven't studied this much.
 Even the heater core is a pain to get to and I think the dash needs to be pulled.
Reply #6May 27, 2022, 10:42:36 am
93Ford
  • 63
« Reply #6 on: May 27, 2022, 10:42:36 am »
Darn, Just figured out my heater core has a leak so know matter what ill have to be digging in there.
Reply #7May 27, 2022, 04:52:12 pm
« Reply #7 on: May 27, 2022, 04:52:12 pm »
Just make a big project out of it will ya?  I would plan on pulling the dash as you might need the working room to get all the problems sorted out.
Reply #8May 28, 2022, 03:40:55 pm
93Ford
  • 63
« Reply #8 on: May 28, 2022, 03:40:55 pm »
Ok so i took everything on the inside apart it was far simpler than i thought. The heater core is totally shot and it seems the heater and ac box are the newer mk2 style but the evap itself is the older style it has the expansion valve on the evap in the ac box. The ac hoses hook straight to the expansion valve on the inside is that normal i thought there was some pipes that hook to it that allowed the hosses to connect on the inside of the firewall.
Reply #9May 28, 2022, 03:55:20 pm
93Ford
  • 63
« Reply #9 on: May 28, 2022, 03:55:20 pm »
I found one thing interesting the ac box has the fan pointed down while all the mk2 boxes iv looked at have the fan pointed straight back
Reply #10May 28, 2022, 05:29:51 pm
93Ford
  • 63
« Reply #10 on: May 28, 2022, 05:29:51 pm »
Welp im about to just give up with this ac system as i guess i have some kind of rare in between year box that i cannot find anywhere. It has the expansion valve in the box with the evap but the whole box is similar to the normal mk2 box except the blower fan is pointed down instead of torward the passenger. Really strange this thing is I guess ill get it fixed up and maybe sometime down the road ill get another jetta with the normal/more common ac setup.
Reply #11May 30, 2022, 11:34:36 pm
  • 2932
« Reply #11 on: May 30, 2022, 11:34:36 pm »
The Mk2s have a problem with the foam on the blend doors falling off.
 While this can be fixed without pulling the dash,
since you have it off you might as well use some aluminum foil tape
to cover the blend door holes.
Reply #12May 31, 2022, 08:58:02 am
srgtlord
  • 797
« Reply #12 on: May 31, 2022, 08:58:02 am »
Definitely an oddball setup.... Maybe the A/C system was retrofitted at the dealer?  Sounds like they used the center section from an A/C vent unit and used the non/ac fan. If memory serves correctly the fan duct section is held in place with a number of tiny  clips making this setup possible but not practical for most people. Honestly I wonder why they didnt use the entire a/c duct work....
Reply #13May 31, 2022, 09:43:02 am
93Ford
  • 63
« Reply #13 on: May 31, 2022, 09:43:02 am »
on this system i was looking for those little clips but there was none just some aluminum tape
