Author Topic: Boosting to 10 psi while NOT driving  (Read 2401 times)
February 20, 2022, 04:49:56 pm
  • 4553
« on: February 20, 2022, 04:49:56 pm »
I am suspicious of my head gasket letting loose only once I get to 10 psi of boost.  I have used the glove on the reserve tank and it never inflates at idle or if I Just Rev IT!
I think I need to get the boost up but how can I do that without tying the back end down to something and slipping the clutch a bunch while holding the throttle down.
Has anyone done this successfully before?  I don't want a Darwin Award for launching my Caddy into the house or into the street and take out some poor Escalade.
Thoughts and comments are welcome, just make em reasonable eh?
Reply #1February 20, 2022, 08:35:21 pm
  • 2932
Re: Boosting to 10 psi while NOT driving
« Reply #1 on: February 20, 2022, 08:35:21 pm »
So you are trying to see how high the pressure is in the coolant reservoir when the boost is at 10psi?
 But you can't get boost without load.
Swap to a VNT-15,.. you can get boost of 10 with no load, ha.
Otherwise, a pressure gauge on the coolant line while watching the boost under load might work.
Reply #2February 21, 2022, 03:09:53 pm
  • 4553
« Reply #2 on: February 21, 2022, 03:09:53 pm »
Yeah, I was trying to get it to boost to 10 without it moving.  I don't think the e-brake is good enough to hold it at 2800 RPM.  I don't have three feet to be able to hold the brake down and slip the clutch while pushing on the accelerator.  I might try doing that with a stick, maybe.
I also thought about the boost gauge hooked up to the coolant lines, a tee at the reservoir might be all I need.
