Author Topic: water meth injection and safe egts  (Read 2793 times)
January 15, 2022, 08:55:52 pm
85bertajetta
  • 17
    trying to save an abused jetta
« on: January 15, 2022, 08:55:52 pm »
just curious if anyone has any experience with water meth injections on a mf td and also what would be a safe egt to run and what's the danger zone on these getting lots of different answers. car is going to have bov blocked and boost controller on waste gate and the stock pump turned up. I'm not wanting to hurt this engine as I just did a full rebuild I have also ported the head and manifolds
Reply #1January 15, 2022, 09:12:01 pm
Ohiobenz
  • 77
Re: water meth injection and safe egts
« Reply #1 on: January 15, 2022, 09:12:01 pm »
I have pretty much that setup now with a K14.
Just installed ARP head studs and O-ringed the block. Per Giles recommendation I also did ARP main bearing bolts - he said they're known to let go above 20psi.
I do have a forced air Passat  Intercooler which keeps my EGT in the 1000F or below range most of the time.
Being hard on the skinny pedal, with a bad wastegate I saw 32psi at 3500rpm, 1300F EGT, 230F coolant temps.
'88 Suzuki Samurai with '85 1.6 TD
K14 turbo
BOV eliminated
Giles performance built IP
Reply #2January 15, 2022, 09:19:43 pm
85bertajetta
  • 17
« Reply #2 on: January 15, 2022, 09:19:43 pm »
my engine is fairly stock other then it being ported and .40 over pistons but now I'm worried about the bottom end lol hopefully it holds together as parts seem hard to fine. I'm new to the vw diesels but not new to diesel in general i have owned a few diesel trucks that I have hopped up but the idi engines are new
Reply #3January 15, 2022, 09:34:05 pm
Ohiobenz
  • 77
« Reply #3 on: January 15, 2022, 09:34:05 pm »
I found mine was bored .030 when I pulled the head to do the O-rings and ARP.
With the K14 and blocked BOV it has boost pretty much right away.
Giles tuned my pump for 25psi and I'm still reassembling.  This is in a Suzuki Samurai, not built for road racing lol.
At those boost levels an IC is pretty necessary.  I also wrapped my down pipe and louvered the hood above the IC in order to lower temps a bit under the hood.
K14 turbo
BOV eliminated
Reply #4January 15, 2022, 09:40:37 pm
85bertajetta
  • 17
« Reply #4 on: January 15, 2022, 09:40:37 pm »
i plan on intercooler eventually when i upgrade turbo but for now i hope the meth injection works enough
Reply #5January 17, 2022, 09:26:21 am
Ohiobenz
  • 77
« Reply #5 on: January 17, 2022, 09:26:21 am »
Do you still have that front cover spring clip? I'm wrapping my 1.6td up.
Hope to start it this week.
K14 turbo
BOV eliminated
