Author Topic: 1.6 TD lifter shims needed  (Read 4015 times)
December 23, 2021, 04:47:52 pm
Ohiobenz
  • 77
« on: December 23, 2021, 04:47:52 pm »
The PO didn't remove the cam lock tool and broke the tail end of the cam.
I just received a new/used cam and need a couple lifter shims to get it all in spec.  Who/where do I go?
Thanks!
'88 Suzuki Samurai with '85 1.6 TD
K14 turbo
BOV eliminated
Giles performance built IP
Reply #1December 23, 2021, 09:28:10 pm
  • 2932
Re: 1.6 TD lifter shims needed
« Reply #1 on: December 23, 2021, 09:28:10 pm »
I think autohausAZ still has a few,
 What sizes are you looking for?
Reply #2December 25, 2021, 09:13:50 am
Ohiobenz
  • 77
« Reply #2 on: December 25, 2021, 09:13:50 am »
3.65
Found on ebay.
I got tired of calculating so made a little spreadsheet that figures out the min/max shim thickness.
Will gladly share if someone wants it.
K14 turbo
BOV eliminated
Reply #3December 29, 2021, 08:43:57 am
jhax
  • 328
« Reply #3 on: December 29, 2021, 08:43:57 am »
Ill take one! Gotta do some shimming on my T3 with a 1.6TD
Reply #4December 29, 2021, 10:38:36 am
Dakotakid
  • 1240
« Reply #4 on: December 29, 2021, 10:38:36 am »
If you need shims in that range, I have a small mountain of them. I may have already thrown a bunch of those away.
Reply #5December 29, 2021, 02:51:00 pm
« Reply #5 on: December 29, 2021, 02:51:00 pm »
Autohaus sells most of them from 2.85 to 3.90 for $2 each.
Reply #6December 31, 2021, 06:32:08 am
Ohiobenz
  • 77
« Reply #6 on: December 31, 2021, 06:32:08 am »
Thanks, I made a spreadsheet calculator to work out min and max shims. The two 3.65 were all I needed along with shifting two more around.
Heads back together and on.
K14 turbo
BOV eliminated
