Author Topic: updating idi  (Read 4585 times)
November 05, 2021, 09:06:24 am
updating idi
« on: November 05, 2021, 09:06:24 am »
Have been getting my 86 td jetta improved,
I found  the exhaust manifold had loose nuts on the ends of the manifold. Suddenly the car started sounding like a tractor again. Put on some VDO gauges and now can verify the oil press, water temp and boost. Seems normal.
I took the top off the boost enricher on the pump and rotated the diaphragm about 180 deg. Now the boost comes up faster and the car accelerates better.
Need to put on a valve cover gasket.
Looks like this forum is on it's knees. Have always found good advice here.
Reply #1December 20, 2021, 10:55:55 am
Ohiobenz
  • 77
Re: updating idi
« Reply #1 on: December 20, 2021, 10:55:55 am »
Not too many people left running the little 1.6TD :-(
'88 Suzuki Samurai with '85 1.6 TD
K14 turbo
BOV eliminated
Giles performance built IP
Reply #2December 20, 2021, 06:33:09 pm
  • 2932
Re: updating idi
« Reply #2 on: December 20, 2021, 06:33:09 pm »
Use the one piece, reusable, rubber valve cover gasket for the gasser 2.0 ABA block.
Reply #3December 20, 2021, 09:42:44 pm
Re: updating idi
« Reply #3 on: December 20, 2021, 09:42:44 pm »
Sounds good
A 2l gas with something called an aba block
Something to research
tks
Reply #4December 21, 2021, 07:52:16 am
Re: updating idi
« Reply #4 on: December 21, 2021, 07:52:16 am »
Like this one fatmobile? Is this what you use?
https://www.evwparts.com/vwparts/Tune2_0ABA/051103483A.html
They seem to want the 1.6 diesels to have the two part gasket on other sites.
Reply #5December 21, 2021, 08:31:44 am
  • 4553
Re: updating idi
« Reply #5 on: December 21, 2021, 08:31:44 am »
Scrounger, it is the two-part nature and the lack of a good seal above the cam on the passengers' side that makes the stock one a pain.  I like the one-piece for solving that bit of frustration.
Reply #6December 21, 2021, 09:08:06 am
Re: updating idi
« Reply #6 on: December 21, 2021, 09:08:06 am »
I have had other vehicles with two part seals and usually that is where they give leakage.
So this part fits without problems?
I have some oil down the back side of the motor and the bolts seem to be snug. Figured that is the next motor item on my list.
I also want to see if there is a baffle under the cam cover as it seems to be some oil being sucked into the engine from the port that goes between the valve cover and intake boot.
Reply #7December 21, 2021, 10:32:43 pm
  • 2932
Re: updating idi
« Reply #7 on: December 21, 2021, 10:32:43 pm »
Hard to tell if that is the right one.
 It's a rubber one-piece,..
but some of them are stiff and some are all flexy.
 I like the victor brand ones with metal support so they are stiff.
The ABA block was used in '93 to ??? Jetta 2.0 gassers.
 Here are some more but I don't see any victor.
The elring might be stiff.
https://www.fcpeuro.com/Volkswagen-parts/Jetta/?year=1994&m=4&e=975&t=6&b=5&d=350&v=13&keywords=valve%20cover%20gasket
There are quite a few posts about this upgrade.
 The stock studs have bald spots that keep the nuts from tightening down on the thinner valve cover.
 The ABA cover is aluminum.
I replace them with set screws but some just add washers.
Reply #8December 22, 2021, 05:54:42 am
Re: updating idi
« Reply #8 on: December 22, 2021, 05:54:42 am »
Thanks for the link, Fatmobile,
I did a search for an  ELRING 915.653 and found a close up picture. Sure looks like it does have an aluminum plate. Thanks
 An aluminum cam cover would be nice.
« Last Edit: December 22, 2021, 06:38:08 am by scrounger »
Reply #9December 22, 2021, 06:56:25 am
srgtlord
  • 797
Re: updating idi
« Reply #9 on: December 22, 2021, 06:56:25 am »
Another nice upgrade is fitting the biggest battery and a 2001 automatic tdi starter to the 1.6. Makes winter starting a breeze :)
Reply #10December 22, 2021, 07:37:16 am
Re: updating idi
« Reply #10 on: December 22, 2021, 07:37:16 am »
Did not know that srgtlord.
The battery in my Jetta has been in it for over 11 years. Still has 12.6 resting voltage. It is an Optima with the cylindrical cells. It was in the car when I purchased it.  Batteries just don't last that long, has me baffled.
Reply #11January 04, 2022, 03:10:39 pm
Re: updating idi
« Reply #11 on: January 04, 2022, 03:10:39 pm »
The manufacture of batteries has changed.  I have a couple from ~2012 that are still going strong, but anything made recently fails within two or three years.
