Gear Oil recommendations
Topic: Gear Oil recommendations (Read 5848 times)
October 25, 2021, 07:20:02 pm
monst
October 25, 2021, 07:20:02 pm »
I can't believe how clean the inside of this transaxle is.
300k....... I would like to put in new gear oil, being that
I drained out the old due to installing new clutch etc. etc.
What is the general consensus recommendation on gear oil.. Brands... and Visco.....
It's a 92 with the fivespeed...
thanks, Monst
October 29, 2021, 08:40:58 pm
sgnimj96
Re: Gear Oil recommendations
October 29, 2021, 08:40:58 pm »
Valvoline Syncromesh unless you live somewhere super hot or race it.
81 Scirocco 1.6D (conversion) 86 Gofl 1.6D 2003 Golf Tdi 1985 300TD
November 01, 2021, 11:24:22 am
srgtlord
November 01, 2021, 11:24:22 am »
Personally I use sta-lube 85w-90 from NAPA because it comes in a gallon container and is GL-4 rated. I live in newengland and during the winter I let the car warm up awhile before driving anywhere
November 02, 2021, 11:52:02 am
monst
November 02, 2021, 11:52:02 am »
Thanks!
I can look it up but, does anyone know off hand..
Transaxle Capacity.......
November 02, 2021, 08:32:57 pm
Moderator
4553
November 02, 2021, 08:32:57 pm »
I think it depends on your transmission. Best to look it up. I think I bought two quarts a bit ago and used maybe 1.5? Not sure but the Valvoline brand came in these nice foldable packages. Nice for use in a tight spot.
November 03, 2021, 09:17:58 pm
monst
November 03, 2021, 09:17:58 pm »
Thanks!
Hard to find stuff at the moment.....
We'll have to see what I get on the lube.... got NAPA around here soooo..... might be NAPA
Try tomorrow some more.... for some Redline....
November 03, 2021, 10:29:47 pm
November 03, 2021, 10:29:47 pm »
Lot of people used to recommend Redline MTL.
Make sure your flange seals are good.
I remember a friend filling his trany and having that red stuff run right out the flange seals and onto the floor.
November 04, 2021, 11:20:03 am
monst
November 04, 2021, 11:20:03 am »
Yeah, I can see that with the MTL....... it is a little thinner....
I think I have some MT-90 I can get tomorrow.....(that is what they said) actually two places.
Yeah, Had the tranny out so installed drive flange seals.... Did all the seals..
Hoping for a leak proof scenario.... Get this puppy running again.....
November 04, 2021, 07:11:14 pm
srgtlord
November 04, 2021, 07:11:14 pm »
If you ever have trouble with the hockey puck seals on the transmission permatex 2a works wonders for keeping them in place
November 23, 2021, 02:15:19 pm
monst
November 23, 2021, 02:15:19 pm »
GTK..... Yeah, I heard that they can sometimes leak.....
Yeah, tranny is all sealed up with new seals. I cleaned off
all the grunge, hopefully it stays that way. I can better see
where problem leaks are now(and hopefully there are none/less)....
I didn't put on a new oil pan gasket. I did a new
valve cover gasket and did a new seal on the vacuum pump.
I just have to throw on some tires and lower it. I ran it to
operating temps twice now(up on the jack stands) she
seems pretty happy, though I have to get a new exhaust flange
made.... So at the moment I am running an open exhaust(somewhat).
November 23, 2021, 09:16:48 pm
November 23, 2021, 09:16:48 pm »
The rubber valve and oil pan gaskets from a 2.0 ABA block are a nice upgrade to the cork and pieces valve cover gasket.
Reply #11
November 24, 2021, 07:42:26 pm
monst
Reply #11 on:
November 24, 2021, 07:42:26 pm »
That is good to know thanks!
Yeah, cork is Passe.
Last Edit: November 24, 2021, 08:10:39 pm by ORCoaster
Reply #12
November 26, 2021, 02:21:20 pm
monst
Reply #12 on:
November 26, 2021, 02:21:20 pm »
Car shifts beautifully.
(new clutch)
I bought some sorta kit and replaced some parts of the shift linkage.
296K car is tight. I just gotta get the exhaust tied in. I have been
running it with open exhaust, be nice to hear other thingzzzz...
But, she has a new lease on life...
BTW: I have two Jettas...(but only one hood!)
Thanks!
Last Edit: November 26, 2021, 08:35:19 pm by ORCoaster
Reply #13
December 23, 2021, 04:50:11 pm
Ohiobenz
Reply #13 on:
December 23, 2021, 04:50:11 pm »
I've used Lucas synthetic for the last several years and am happy with it. NAPA carries it.
'88 Suzuki Samurai with '85 1.6 TD
K14 turbo
BOV eliminated
Giles performance built IP
Reply #14
June 23, 2022, 02:24:18 pm
Reply #14 on:
June 23, 2022, 02:24:18 pm »
I run a mix of redline MTL and MT-90 due to something I read on here years ago. It works good, very thin and at -40 it shifts like butter. It used to stall at -30 with dino 75w-90.
