Model Specific Questions and Info
MK2 Golf/Jetta and Audi 5k
TOP OF STRUT MOUNTING LOOSE.......NORMAL????
Topic: TOP OF STRUT MOUNTING LOOSE.......NORMAL???? (Read 5095 times)
June 12, 2021, 05:02:58 pm
ftm1776
June 12, 2021, 05:02:58 pm »
If in between the shown positions, I can move the top of the strut around somewhat. Seems weird that it is not
firmly attached to the body. Is this normal??? I think so, but my tire guy brought it to my attention.
The nuts on top of the struts are tight.
TOP OF STRUT WITH WEIGHT ON TIRE
TOP OF STRUT WITH WEIGHT OFF OF TIRE
SHOWN FOR REFERENCE
Thomas, Original and sole owner since new:
1991 Jetta NA 1.6 diesel, Engine Code ME, 5 speed, AWY transmission, Hydraulic Lifters
293,000 miles
LOOKING FOR A GOOD VW DIESEL ENGINE BUILDER ON THE WEST COAST
June 12, 2021, 07:17:15 pm
Re: TOP OF STRUT MOUNTING LOOSE.......NORMAL????
June 12, 2021, 07:17:15 pm »
That's actually normal
June 16, 2021, 10:59:42 am
srgtlord
June 16, 2021, 10:59:42 am »
vw went super cheap on the mk2 strut mounts...
June 17, 2021, 08:48:50 pm
June 17, 2021, 08:48:50 pm »
I've always wondered that too.
Haven't seen any mods that address it.
June 18, 2021, 03:33:21 pm
thomas m
June 18, 2021, 03:33:21 pm »
What is happening with the wheel alignment when the top of the strut is loose when airborne
That's what the alignment guy was questioning. It does seem weird that the top can be moved around....no attachment to the body for some reason?
Then again, my car is older than he is. Old school they call it. No problem for 30 years though and no such comments from other guys at the same shop.
320,000 miles
June 18, 2021, 05:56:39 pm
June 18, 2021, 05:56:39 pm »
Typically the top strut mount bushing allows axial movement but limits radial movement. That axial movement doesn't change the alignment geometry any differently than going over bumps or having the spring compress.
