Model Specific Questions and Info
MK2 Golf/Jetta and Audi 5k
Snapped Camshaft
Topic: Snapped Camshaft (Read 4932 times)
April 04, 2021, 08:31:08 pm
Studdley
Newbie
Snapped Camshaft
April 04, 2021, 08:31:08 pm »
I was spending the weekend giving my mk2 1.6 NA some much needed attention. I resealed the IP new cam cover gasket etc. I went to crank the car, heard a snapping sound and saw the sprocket go limp. The cam snapped between the two lobes for cylinder number 1. Am I good to throw another cam in it or do I need to pull the head and throw a new one on. PS I'm in the market for some 1.6 parts lol
April 05, 2021, 07:16:37 am
srgtlord
Re: Snapped Camshaft
April 05, 2021, 07:16:37 am »
Time for a new head, head-gasket and headbolts if the pistons still look ok
April 05, 2021, 08:48:13 am
Studdley
Newbie
April 05, 2021, 08:48:13 am »
That's what I figured. I must have timed it 180 out.
April 05, 2021, 05:45:49 pm
Moderator
4552
April 05, 2021, 05:45:49 pm »
Timing it 180 out would not have cracked the cam. It will actually run like crap at 180 out, done all the time with those two-hole sprockets on the IP. I have to watch mine. I should just put some paint on the inside of the one that is correct. Maybe bright
RED
I bet you were a couple to three teeth off and it just hit hard on the valve and popped a weak cam.
April 26, 2021, 01:34:32 pm
April 26, 2021, 01:34:32 pm »
Always turn the crankshaft two turns after putting a timing belt back on.
Snapped Camshaft
