Author Topic: Exhaust manifold heat shield studs  (Read 2276 times)
February 04, 2021, 11:15:25 am
BajaVWCamper
« on: February 04, 2021, 11:15:25 am »
Hi all,
Taking my Exhaust manifold i took off the heat shields to get to the exhaust studs easier and of course the old rusty bolt broke off... After Finally carefully drilling out the broken stud i noticed that the bore goes all the way through into the exhaust. My question before i simply drop in a new stud is what should i use as a "loctite" compound? I am assuming it should be a good seal since the back end is inside the exhaust but considering the temps of the header im not sure regular red loctite will cut it. Any suggestions?
Its specifically a JX exhaust manifold and the srud i mean is here
https://photos.app.goo.gl/QXHHiYuota8x3fJh8
Thanks guys!
Reply #1February 04, 2021, 12:41:02 pm
Re: Exhaust manifold heat shield studs
« Reply #1 on: February 04, 2021, 12:41:02 pm »
I use Permatex Ultra Copper in that situation.
Reply #2February 05, 2021, 09:46:21 am
  • 4553
« Reply #2 on: February 05, 2021, 09:46:21 am »
Me too. One of the tubes found at the bottom of the toolbox.  Not used often but nice to have handy.
