General Information
Troubleshooting
"Turbo" Oil Line Replacement
Topic: "Turbo" Oil Line Replacement (Read 5870 times)
August 11, 2006, 05:09:53 pm
Bludodger
User+
August 11, 2006, 05:09:53 pm »
Car--'91 Eco Diesel
Anyone had to replace the oil feed line running from the oil filter housing to the turbo? Is this a dealer only part? Any price range? Any other ideas?
Thanks
Andrew
August 11, 2006, 08:42:58 pm
Bludodger
User+
August 11, 2006, 08:42:58 pm »
I should mention that I discovered the line was leaking at the union off the oil filter housing. I removed the line and found that the ferrule at the end of the line had fused with the intermediate union, I had to take them off together as one unit and can't get them apart. Probably happened because PO over tightened? Anyone have this problem? Solutions? If the answer is a new dealership setup anyone, with access, have the Part number for the line with ferrules and washer which should sit between intermediate union and oil filter housing? Its a one use washer as per Bentleys and my car never had one to begin with.
Thanks
August 11, 2006, 08:58:04 pm
August 11, 2006, 08:58:04 pm »
maybe a lot of penetrating oil.. and something to hit it (not too hard) to get it loose.
August 11, 2006, 10:09:35 pm
Master ACiD
August 11, 2006, 10:09:35 pm »
ive made my own turbo lines with steel brake line and a brake line bender. its rather easy.
August 13, 2006, 09:23:51 am
Bludodger
User+
August 13, 2006, 09:23:51 am »
Thanks for the replies... In terms of replacing them with brake lines, how did you get them properly fitted? Metric fittings?
August 13, 2006, 10:10:16 am
Master ACiD
August 13, 2006, 10:10:16 am »
i imagine you could use metric fittings, but i just reused the old fittings.
August 14, 2006, 06:50:12 am
veeman
August 14, 2006, 06:50:12 am »
Looks like the part numbers (for a 1991 jetta eco) are:
068-145-771A Oil pipe
013 812 8 Sealing washer
021 022 2 Union nut (separate number for just the nut, the "pipe" probably comes with the two you'll need)
021 819 2 Male fitting on turbo (no listing for the oil cooler side, but I assume that one is the same)
Not sure if those parts are available any more or not. You might check the classifieds here to see if anyone's got one for you...
Master Acid... I can't recall, but are the ends on that oil line flared like brake lines (metric "double bubble") or do they have more of a single flare to them? Never thought of making a new line...
*Edit: Whoops...had to find the eco parts... I had previously listed the rabbit parts...
81 Caddy TD
98 Audi A4 Quattro V6 TDI
83 VW GTI FSP
86 4ktq
August 14, 2006, 08:38:33 am
Master ACiD
August 14, 2006, 08:38:33 am »
when i made my turbo line out of brake line it was a while ago, i cant recall how the end of the lines looked.
i do know that most double flare tools are also able to make single flared ends though.
id suggest taking youre line off and examining the ends to see how it looks before you buy anything.
General Information
Troubleshooting
