Author Topic: 1.9 AAZ build, am I missing anything?  (Read 3942 times)
October 26, 2020, 01:36:44 pm
Buji88
  • 39
« on: October 26, 2020, 01:36:44 pm »
Hey all!
I hope everyone is staying safe during these crazy-ass times. I'm wanting to run an idea past all of since everything I've learned about the IDIs have pretty much been from this forum.
Anyways, I put a 1.9 AAZ into a Suzuki sidekick, and its been great, but it's underpowered so I've decided to build my dream AAZ. I've included a list of the mods I plan to make. My goal is for it to be simple and reliable and have 90 - 100 HP.
-AHU crank and timing gear (to help eliminate any potential crank nose issues)
-1.9 AAZ injection pump with a 1.6 TD pump top (simpler)
-1.6 GTD injectors (being able to rebuild/tune in my shop)
-Whichever injectors lines fit better (heard super mixed review on this)
-VR6 oil cooler (maybe Passat one if I can fit it)
-T25 flange manifold
-Probably HE211WG turbo, although it seems it's possible to run the VNT 15 fairly easily (looking into this now, if someone has links Id love to see)
-PD150 intake.
Am I missing anything, any other mods you can think of I should look into doing?
Reply #1October 26, 2020, 02:30:31 pm
Re: 1.9 AAZ build, am I missing anything?
« Reply #1 on: October 26, 2020, 02:30:31 pm »
Intercooler.
Reply #2October 26, 2020, 03:13:55 pm
Buji88
  • 39
« Reply #2 on: October 26, 2020, 03:13:55 pm »
True, left it off the list, already have!
Reply #3October 26, 2020, 03:54:53 pm
« Reply #3 on: October 26, 2020, 03:54:53 pm »
If you are using the stock AAZ serpentine belt system and alternator, then you should definitely install the AHU clutched alternator pulley onto the alt.
Reply #4October 28, 2020, 10:15:28 am
Buji88
  • 39
« Reply #4 on: October 28, 2020, 10:15:28 am »
That is the driving force going to the AHU crank and timing gear because I'm currently running a GM CS 130 alternator with a solid pulley and I plan on going to a CS 144 because it's going to get a winch and dual batteries. With that being said I'm running the belt without a tensioner but the new plan is run the VW style tensioner on the alternator and doing the same for the water pump and power steering pump as well.
Reply #5October 28, 2020, 10:41:13 am
« Reply #5 on: October 28, 2020, 10:41:13 am »
The AHU crank/sprocket will fail with a serp belt and solid pulley on the alt.  It is as simple as that.  It is not unheard of for the AHU crank/sprocket to fail also and I suspect that those cases are caused by the alt pulley seizing so it is no longer spins openly the one direction.
Reply #6October 28, 2020, 01:41:41 pm
Buji88
  • 39
« Reply #6 on: October 28, 2020, 01:41:41 pm »
Good to know, I will be switching that over to a clutched alternator then, it seems like there are tons of options on the GM cases which I need for my build.
Reply #7October 28, 2020, 02:43:26 pm
« Reply #7 on: October 28, 2020, 02:43:26 pm »
There are a decent assortment of clutched sprockets that can update alts with solid sprockets.  You might not need to swap alts and just get an appropriate pulley instead.
