Author Topic: 1.6TD (JX) Serpentine Conversion  (Read 2884 times)
July 19, 2020, 04:04:25 am
dave.arthur
  • 10
« on: July 19, 2020, 04:04:25 am »
Wondering if this modification is a bolt on.
I have a 1.6TD in a T3 Camper (50 degrees stock). It currently has the stock shim system for belt tensioning.
I have an ALH harmonic balancer and an ABF alternator bracket, spring and alternator. I have an iABED water pump pulley.
I am using these for an ALH upgrade this winter coming, but am having problems with the belt system on the 1.6 and would upgrade if it is not a huge job.
The alternator is different so I will need to rewire it, but Im thinking it is doable. Thoughts?
Reply #1July 19, 2020, 07:30:19 am
srgtlord
  • 797
Re: 1.6TD (JX) Serpentine Conversion
« Reply #1 on: July 19, 2020, 07:30:19 am »
Yes it will bolt right up but Im not sure how well it will fit in a van. The ABF looks to be a better setup than the other mk3 tensioner. I bolted up the other mk3 style serpentine setup with the "auto tensioner" to my 1.6D golf and the bracket broke twice before I went back to a v-belt setup
Reply #2July 28, 2020, 12:33:22 pm
dave.arthur
  • 10
« Reply #2 on: July 28, 2020, 12:33:22 pm »
Just a thought, did you have the overrun clutched pulley on the alternator?
Reply #3August 01, 2020, 06:31:46 am
srgtlord
  • 797
« Reply #3 on: August 01, 2020, 06:31:46 am »
yes
